No oil pressure upon warm start-up - JeepForum.com
post #1 of 5 Old 08-08-2010, 10:22 PM Thread Starter
red88MJ
Ok here's what I've got...
02' TJ, 4.0, auto, 84k.
Once the motor is at normal operating temperature if you shut the jeep off and start it again in a few minutes the oil pressure guage stays at 0 psi and the check guages light comes on. It will sit there and idle all day after that with no oil pressure on the guage and the check guages light on but the engine will never once sound like it is lacking oil pressure. As soon as you touch the gas pedal and bring the rpm's up the oil pressure guage will start reading pressure. After you bring the rpms up the guage reads normal (about 20-30 psi at idle and up to 50 psi when the rpms are up). It never drops back down to 0 psi after you bring the rpms up the first time. As soon as you shut off the jeep and start it again it reads 0 psi again and you have to bring the rpms back up to make the guage read normal.
Anyone with any ideas?????
This must be a low range beer because it makes everything slower...
MY LJ BUILD...
red88MJ is offline
post #2 of 5 Old 08-08-2010, 10:39 PM
fishinjeeper
oil pressure sensor
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #3 of 5 Old 08-09-2010, 05:55 PM Thread Starter
red88MJ
ya think so? I'm looking to buy this thing off of a buddy cause he has to get rid of it and its done this since it had 10k on it when he got it. I know some of the first TJ's (97-98 maybe) had issues with the wiring harness plugs where they pluged into the guages. Does anyone know if this was the case with later TJ's too?
MY LJ BUILD...
red88MJ is offline
post #4 of 5 Old 08-09-2010, 06:29 PM
fishinjeeper
I would still say its probably the oil pressure sensor. not that hard to replace and if it fixes the problem then you saved some money instead of takin it to a mechanic. as far as i know the only real wiring harness that around that year that seem to be a constant problem are the blower wiring harness's.
post #5 of 5 Old 08-09-2010, 06:36 PM
herbiehind
change the sending unit
herbiehind is offline
oil pressure , gauge , idle , tj , wrangler
Won't start when warm HolidayJeep TJ Wrangler Technical Forum 25 01-05-2014 05:20 PM
High oil pressure in the warm weather RedTeej TJ Wrangler Technical Forum 2 04-25-2009 04:15 PM
won't start when warm/hot ksjohn YJ Wrangler Technical Forum 1 06-02-2008 04:24 AM
Pre-start warm up? anmal592 YJ Wrangler Technical Forum 4 02-15-2004 05:02 PM
Normal OIL pressure after warm up JKJoe TJ Wrangler Technical Forum 5 07-16-2002 07:48 AM
