No MIL (Check Engine Light) = FAILED inspection?! - JeepForum.com
post #1 of 28 Old 07-25-2012, 05:32 PM Thread Starter
mrfourpointo
No MIL (Check Engine Light) = FAILED inspection?! ------> SOLVED!!
I have been going through an ongoing saga of trying to get my Jeep inspected, and I failed again today. I failed before due to bad catalytic converters (codes PO420 and PO432), although my Check Engine Light was not on. I have now replaced everything from the exhaust manifold back with stock components. I went to get it re-inspected today and the cats are good. However, the inspection failed because my Check Engine Light will not come on. A fellow JF member helped me walk through and diagnose that the light is not properly functioning here:
http://www.jeepforum.com/forum/f9/ch...-bulb-1335275/
Does anybody have any clue as to how to get the light back on? Even when I turn the key to the "on" position the light does not illuminate.
This is beyond frustrating.
Last edited by mrfourpointo; 07-26-2012 at 06:44 PM. Reason: Reflect in title problem solved
mrfourpointo is offline
post #2 of 28 Old 07-25-2012, 05:50 PM
LJameson
Take the cluster out and replace the bulb...
1990 YJ
LJameson is offline
post #3 of 28 Old 07-25-2012, 05:59 PM Thread Starter
mrfourpointo
I assumed it was that easy. Everyone has since told me that there is no bulb, but rather an LED soldered onto the circuit board. The linked thread went through this also.
post #4 of 28 Old 07-25-2012, 06:53 PM
LJameson
Hmm, looks like I might be eating crow. I could've swore there was a bulb on my TJs cluster.
1990 YJ
LJameson is offline
post #5 of 28 Old 07-25-2012, 07:37 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
TJ's have bulbs. LED's wernt thrown into the mix until the JK
My builds:
and
or follow us on
spyder6 is offline
post #6 of 28 Old 07-25-2012, 08:23 PM
randytj123
you have some weird rules in the states not a thing like that here for a safe
randytj123 is offline
post #7 of 28 Old 07-25-2012, 08:48 PM
beefcake3
may or may not help but hes changing the bulbs in the cluster
http://www.jeepforum.com/forum/f9/ga...nstall-752937/
beefcake3 is offline
post #8 of 28 Old 07-25-2012, 09:12 PM Thread Starter
mrfourpointo
It looks like the TJ instrument panel changed during production. I have a 2004 TJ and my panel is different than the one pictured in that thread. I have fewer bulbs than in that panel and the ones that I do not have appear to be in the locations of warning lights. Please see the pictures below for comparison.
Here is the back of my panel:
Here is the panel referenced in that thread:
post #9 of 28 Old 07-25-2012, 09:18 PM
CJ Chet
The 2004 TJ has LED's, NOT bulbs. The FSM says they are not serviceable. Being an ex electronic Tech I would say that they probably are if you have the soldering skills. The more difficult problem would be sourcing the replacement parts.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #10 of 28 Old 07-25-2012, 09:21 PM
spyder6
spyder6's Avatar
2010
are you sure? when i pulled my 06's cluster i could have sworn i saw bulbs all over the whole thing. im 95% confident.
My builds:
and
or follow us on
spyder6 is offline
post #11 of 28 Old 07-25-2012, 09:33 PM
CJ Chet
There are alot of bulbs in there for general ilumination, etc., but the MIL indicator is an LED. Sorry, guess I didn't word that very well.
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #12 of 28 Old 07-25-2012, 09:44 PM Thread Starter
mrfourpointo
Assuming it is an LED, how would someone have gone about diabling that light? The picture above is as far as I disassembled the cluster because I was cautious about opening the white plastic housing. Any harm in going in further? Has anybody opened that before, and if so, would a broken LED be recognizeable?
post #13 of 28 Old 07-26-2012, 05:31 AM
spyder6
spyder6's Avatar
2010
a 'burnt out' LED is extremely uncommon most low power LED's have a burn life of 50,000 hours. to repair it you'd have to remove it from the board and solder a new one on if you can find something of appropriate size. it would probably be easier to just find a new panel
My builds:
and
or follow us on
spyder6 is offline
post #14 of 28 Old 07-26-2012, 05:47 AM
lynn
lynn's Avatar
Chances are much better that a solder connection broke, than the LED actually burning out.
I agree easiest solution is to locate a new panel.
Lynn
'05 LJ
lynn is offline
post #15 of 28 Old 07-26-2012, 08:03 AM Thread Starter
mrfourpointo
Looks like the new panel runs about $800. That is one expensive light bulb.
check engine light , inspection , mil , smog
failed Inspection Doty152 Wrangler General Discussion 15 09-25-2011 04:47 PM
I failed inspection:/ Collin89Sahara YJ Wrangler Technical Forum 6 06-28-2011 03:09 PM
Inspection and Check Engine Light SKIBUMM TJ Wrangler Technical Forum 9 05-23-2008 11:09 AM
TJ Failed inspection firefly TJ Wrangler Technical Forum 9 06-07-2006 01:58 PM
Failed Inspection Need Help ! zex TJ Wrangler Technical Forum 8 07-15-2004 12:05 AM
