No Heat and winter is coming!
| TJ 5.25" Speaker Adapters - NalinMFG | Spartan Lockers FREE SHIPPING Excellent Prices | Rough Country Deals at JeepHut.com |
#1 | |
Ok, So before it started to get really cold my heater was blowing air that was hot enough to cook with. Now it decided to only blow slightly warm air. What is the problem? Heater Core clogged possibly?
#2 |
Stormaggedon
Most likely, a thermostat that is stuck open, which won't allow your engine to reach operating temperature, and you'll get no heat. Does your temperature gauge reach 190-210? If not, test/replace the thermostat.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine We work together every damn day. --Jon Stewart Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it. Low Output 4 Cylinder Jeep Club member #188 |
#3 |
do the hoses going to and from the fire wall get hot. if one is and the other isnt, prob. clogged. but id start with the t,stat.
tellicojeeper |
#4 | |
I'll have to check the hoses tomorrow, should I check them with the heater on? off? doesn't really matter? |
#5 |
check with heater on.
Also check coolant level.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift 84 CJ7; frame off restoration in progress. The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice. |
#6 |
I say it could well be your Thermostat. Go ahead and check the Heater Hoses when the engine is hot just to rule it out. But you said your TJ reaches around 180-190F, which sounds suspect. I could see between 195-200F on a long drive, but not 180-190F. My TJ is a '97 and hasn't run extended much under 210F in years, even with fresh coolant and a new Radiator Cap.
If it's your Thermostat, replacing it is a messy but fairly easy and straightforward job. I used to swap the Thermostat out of my 1970 Ford Maverick twice a year - Either the 160F or 180F for the hot Southwestern Summers, and the OEM Spec 190F for Winter. When I moved to the Upper Midwest in February '02 for a bit, I hadn't swapped out the Summer Thermostat yet. The difference between 10-20 Degrees with Thermostats made a huge difference...it was a miserably cold driving experience. Just warm enough to defrost the windshield but I had to wear a hat, gloves and keep my jacket zipped until April/May.
'97 Jeep TJ (SE) - Crumple-Zones Not Included! |
#7 |
Another possibility is the blend door may not be moving fully to the hot positon. If it's sticking, or not moving you'll get poor heat.
#8 |
Well both hoses are hot...really hot. So I'm going to say either thermostat or the blend door isn't working properly
#9 |
if the hose are hot then the core is hot. need to check the blend door. it will keep from the heat entering the blower motor
tellicojeeper |
#10 |
Had the exact same problem. Does your TJ take forever to get up to operating temps?
If so then your likely culprit is your water pump -$32.00 from auto parts store. Do your tstat and do a good flush and you'll be fine, but be sure to do a reverse flush to get the gunk out of your heater core. My hoses felt like it was a tstat too but after swapping it didn't make a difference. The new pump did. B sure to see if it is a reverse flow - you can tell if there is an R stamped on the impeller.
-Paul Green Jeep Member #155 Low Output 4 Cylinder Jeep Member #35 Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
