no gauge or fan lights - JeepForum.com
post #1 of 21 Old 06-21-2013, 07:46 PM Thread Starter
craig02tj
just bought this jeep about 3 weeks ago...already replaced motor and just tieing up loose ends. i have no gauge lights but my dome light works...just removed the cluster and bench tested the lights on a 12 volt supply and they work. is there a fuse im missing i looked behind glovebox and the fuse i think number 10 for cluster is good i even swapped with turn fuse and still nothing. and i just noticed the fan controls are not lighting up. any ideas? thanks in advance!
craig02tj is offline
post #2 of 21 Old 06-21-2013, 09:04 PM
mukluk
Fuse 10 is power for the cluster, fuse 3 is the one you need to check for your gauge and dash lighting.
mukluk is offline
post #3 of 21 Old 06-21-2013, 09:20 PM Thread Starter
craig02tj
Ok my fuse 3 is good but the diagram shows thats for subwoofer system?
post #4 of 21 Old 06-21-2013, 10:07 PM
mukluk
Sorry, looked at the wrong diagram... should be fuse 1 for the multifunction switch.
Are your parking lights working?
mukluk is offline
post #5 of 21 Old 06-22-2013, 07:11 AM Thread Starter
craig02tj
Yes everything works fine just no gauge lights
post #6 of 21 Old 06-22-2013, 01:14 PM
mukluk
If you go to this link, you can pull up the wiring diagrams for your 2002 TJ: http://www.jeep4x4center.com/knowledge-base/index.htm
I'd say check for power at connector C107, Pin B10 and at connector C202, Pin A5 when you have the parking lights turned on.
mukluk is offline
post #7 of 21 Old 06-25-2013, 10:38 AM
alabus
Dealing with same issues, I know this doesn't sound right but is your jeep an automatic transmission?
alabus is offline
post #8 of 21 Old 06-25-2013, 10:45 AM Thread Starter
craig02tj
Yes auto I can't figure it out lol
post #9 of 21 Old 06-25-2013, 10:53 AM Thread Starter
craig02tj
Why you ask if auto? Just wondering?
post #10 of 21 Old 06-25-2013, 01:16 PM
NotURMailman
Dash dimmer?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #11 of 21 Old 06-25-2013, 01:28 PM Thread Starter
craig02tj
Well the odometer dims with it just no dash lights fan or gear lights all turns parking sop all that works just the gauges
post #12 of 21 Old 06-25-2013, 01:28 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
May need to replace some dash lights then. Pull the cluster and check power to the harness.
RnEmOvr is offline
post #13 of 21 Old 06-25-2013, 01:38 PM Thread Starter
craig02tj
Tested with 12 volt box all are good
post #14 of 21 Old 06-25-2013, 02:05 PM
RnEmOvr
RnEmOvr's Avatar
So the lights are getting power or they work when you applied them direct to the battery?
RnEmOvr is offline
post #15 of 21 Old 06-25-2013, 02:15 PM Thread Starter
craig02tj
No power from dash I tested the bulbs on battery
cluster , gauge , lights
