-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   no gauge or fan lights (http://www.jeepforum.com/forum/f9/no-gauge-fan-lights-1539653/)
craig02tj 06-21-2013 07:46 PM
just bought this jeep about 3 weeks ago...already replaced motor and just tieing up loose ends. i have no gauge lights but my dome light works...just removed the cluster and bench tested the lights on a 12 volt supply and they work. is there a fuse im missing i looked behind glovebox and the fuse i think number 10 for cluster is good i even swapped with turn fuse and still nothing. and i just noticed the fan controls are not lighting up. any ideas? thanks in advance!
mukluk 06-21-2013 09:04 PM
Fuse 10 is power for the cluster, fuse 3 is the one you need to check for your gauge and dash lighting.
craig02tj 06-21-2013 09:20 PM
Ok my fuse 3 is good but the diagram shows thats for subwoofer system?
mukluk 06-21-2013 10:07 PM
Sorry, looked at the wrong diagram... should be fuse 1 for the multifunction switch.
Are your parking lights working?
craig02tj 06-22-2013 07:11 AM
Yes everything works fine just no gauge lights
mukluk 06-22-2013 01:14 PM
If you go to this link, you can pull up the wiring diagrams for your 2002 TJ: http://www.jeep4x4center.com/knowledge-base/index.htm
I'd say check for power at connector C107, Pin B10 and at connector C202, Pin A5 when you have the parking lights turned on.
alabus 06-25-2013 10:38 AM
Dealing with same issues, I know this doesn't sound right but is your jeep an automatic transmission?
craig02tj 06-25-2013 10:45 AM
Yes auto I can't figure it out lol
craig02tj 06-25-2013 10:53 AM
Why you ask if auto? Just wondering?
NotURMailman 06-25-2013 01:16 PM
Dash dimmer?
craig02tj 06-25-2013 01:28 PM
Well the odometer dims with it just no dash lights fan or gear lights all turns parking sop all that works just the gauges
RnEmOvr 06-25-2013 01:28 PM
May need to replace some dash lights then. Pull the cluster and check power to the harness.
craig02tj 06-25-2013 01:38 PM
Tested with 12 volt box all are good
RnEmOvr 06-25-2013 02:05 PM
So the lights are getting power or they work when you applied them direct to the battery?
craig02tj 06-25-2013 02:15 PM
No power from dash I tested the bulbs on battery
The time now is 10:51 PM.
