Quantcast No first/second/reverse gear. Reverse clanks - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > No first/second/reverse gear. Reverse clanks
Old 02-15-2009, 07:33 PM   #1
lunchbox101
Me and a buddy were driving up this old logging trail until we couldnt get any farther. After being pulled backwards uphill, out of some snow, we continued to drive back down the hill.
It cleared into this opening, with a dirt mound with some snow, on which i proceeded to drive up, slide sideways, and stop. i then tried to put it in reverse, and it would just grind, in 2wd 4wd and 4wdl. first and second gear did the same thing. after messing with it, by putting the transmission in neutral, and then putting it in first, i was able to drive all the way back down the hill. got to an open parking lot, and then i couldnt put it in any of the gears, until i continued to mess with it some more.
By 'mess with it', i mean shifing between 2wd and 4wd, neutral, and trying to put it into gear.
After a while of this, i can now shift into first and second without putting in the clutch, and it doesnt grind or anything. i can also put it into reverse, let out the clutch, and it makes a clanking noise.
Third, fourth, and fifth gear are perfectly fine, and i can start out in third and it will drive and shift to fourth and fifth normally
This sounds familiar to anyone??
I havent searched yet because i dont have time, but in the next hour, ill get a few pics up of where i was stuck, and also search for similair problems.
thanks guys
edit: also, ive had it for about three weeks or so, it has 121k miles, ive put on about 400 or so. not sure how many previous owners. bought it from a dealership without warranty
lunchbox101 is offline   Reply With Quote
Old 02-15-2009, 07:37 PM   #2
lunchbox101
pics. i pulled up there so my friend could go first
Old 02-15-2009, 07:41 PM   #3
Diabl0
Trail Retard
Diabl0's Avatar
Diabl0 is offline   Reply With Quote
Old 02-15-2009, 09:42 PM   #4
lunchbox101
bump
searched, but cant find anything similair...
Old 02-16-2009, 12:38 AM   #5
lunchbox101
no replies..? well im taking it into the transmission shop tomorrow..ill update this thread then
Old 02-16-2009, 05:40 AM   #6
04tjor
You might have just damaged those particular gears. It is unusual. As a mechanic myself, don't hear of this too often. What does the linkage look like. It's possible the lever looks like it's in gear when the linkage is only half way. Thus grindage. The clunk might be the mount. Reverse is different then all forward gears and therefor can have different problems associated with it.
04tjor is offline   Reply With Quote
Old 02-16-2009, 02:29 PM   #7
lunchbox101
drove it in third gear to the transmission shop.
guy estimates 1200-1800
going to get the clutch changed at the same time...
sound about right?
Old 02-16-2009, 09:56 PM   #8
lunchbox101
really? no opinions?
Glock Forum
