No electric when key is turned... - JeepForum.com
post #1 of 6 Old 07-19-2010, 06:12 AM Thread Starter
MikeTheVike
When I turn the key either direction nothing happens. I've had no problems, drove it all weekend. The battery terminals are a little crusty, but I cleaned them a bit and they should be good. Fuses look good...any ideas? I need to get to work, haha.
MikeTheVike is offline
post #2 of 6 Old 07-19-2010, 06:14 AM
jerryjeeper
Check neutral safety switch or jostle the shift lever while trying to start.
jerryjeeper is offline
post #3 of 6 Old 07-19-2010, 06:19 AM
mdm
Farm Wheeler
Lights, radio, turn signals, brake lights?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 6 Old 07-19-2010, 06:29 AM Thread Starter
MikeTheVike
craaaaaappp, just went out there to check the things jerryjeeper mentioned and noticed my headlights switch was turned on. They were on from around 6pm yesterday. I have a friend coming to jump me, that should do it I think.
post #5 of 6 Old 07-19-2010, 06:35 AM
mdm
Farm Wheeler
You'll need to put the battery on a charger. Just jump starting and expecting the battery to recharge itself as you drive isn't going to work well and you will most likely have problems; low idle, rough running,...
mdm is offline
post #6 of 6 Old 07-19-2010, 10:19 AM Thread Starter
MikeTheVike
Yea the jump didn't work, the battery was still under warranty so I went and replaced it. Thanks everyone for the help!
no electric , electrical , tj , wrangler
90 amp alternator turned into 136 amp rockstedy YJ Wrangler Technical Forum 39 01-11-2011 10:01 PM
The 88 YJ: Fix turned to build kgillette YJ Wrangler Technical Forum 4 03-02-2010 09:38 AM
No ignition when key is turned Lloyd1967 YJ Wrangler Technical Forum 4 01-24-2010 08:26 PM
Scrapper turned in a TJ BARKDOG67 Wrangler General Discussion 7 03-15-2009 09:22 PM
Having the Flywheel turned? MusicMaverick YJ Wrangler Technical Forum 1 04-08-2003 08:45 PM
