NO drill rocker guards - JeepForum.com
 3Likes
post #1 of 37 Old 01-11-2011, 08:01 PM Thread Starter
jabroni3411
I want to add some rocker guards but not to interested in drilling holes in the side of my jeep. Anyone know of metal rocker guards that either use the existing holes from the mini flare and/or bolt under the body possibly? Thanks
Check My Build
jabroni3411 is offline
post #2 of 37 Old 01-11-2011, 08:07 PM
Imped
Imped's Avatar
If you actually put the guards to use, the tub will be dented. It's just not feasible. Rocker guards protect the tub much more than drilling a few holes will "harm" it. Besides, once you bolt up rocker guards, you'll always have rocker guards. There's no reason to be afraid of some drilling.
OlllllllO
IndyORV
Imped is offline
post #3 of 37 Old 01-11-2011, 08:09 PM Thread Starter
jabroni3411
point taken!
Check My Build
post #4 of 37 Old 01-11-2011, 08:44 PM
02OlllllllOTJ
remember the first cut is the hardest. youll learn drill holes, hole saws and cut off wheels are your friends
matthew900 likes this.
Originally Posted by 02OlllllllOTJ View Post
that much pabst blue ribbon will give you a hangover strong enough to slay a walrus
02OlllllllOTJ is offline
post #5 of 37 Old 01-11-2011, 08:46 PM
freeskier93
It's either drill, or weld big sliders to the frame, like what I have.
freeskier93 is offline
post #6 of 37 Old 01-11-2011, 09:04 PM
Humboldt
Humboldt's Avatar
Drill or use duct tape. At least when the duct tape fails to protect your rockers, you can use it to 1,000,000 other things.
Humboldt is offline
post #7 of 37 Old 01-11-2011, 09:08 PM
pcoplin
There aren't magic rockers - they'll have to bolt or weld on.
FullStack MotorSports
pcoplin is offline
post #8 of 37 Old 01-11-2011, 09:11 PM
EjTj
I put on Body Armor Rock Crawler side guards and they didn't require drilling. They act as a step and mount into the body mounts. I didn't care whether they were no-drill, I just liked them and the price (and they've gone down in price since I bought mine). I also have some diamond plate rocker guards. I like them both.
EjTj is offline
post #9 of 37 Old 01-11-2011, 09:15 PM
NMLJ
NMLJ's Avatar
If you wheel, dont get the ones that just use your existing body mount bolts. They will deflect off rocks in hard impacts, and damage your tub. I had to get the body mount style sliders to cover the damage from the no drill style.
/l ,[___],
l--L --OlllllO-
()_) ()_)-o-)_)
-2006 Impact Orange LJ-
MY BUILD THREAD
THE HARDEST THING ABOUT A ZOMBIE OUTBREAK WOULD BE PRENTENDING NOT TO BE EXCITED
NMLJ is offline
post #10 of 37 Old 01-11-2011, 09:37 PM
IslandTJ
Mine were stupid simple to install and did not require drilling or welding to mount. They are not tub mounted as I needed a functional step for my wife and kids (at the time). They are very stout and adequately protect the side of my Jeep, I even use them as a pivot point when called for.
Now Jeeping in Oregon
IslandTJ is offline
post #11 of 37 Old 01-11-2011, 09:48 PM
freeskier93
How are yours connected? Just curious because I have the same kind of thing (pictured above) but mine are welded to the frame.
post #12 of 37 Old 01-11-2011, 09:54 PM
Bennettj13
**** these guys. I used liquid nails and it worked fine.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #13 of 37 Old 01-11-2011, 09:56 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I need a step also, this works well for me:
Knuckelhead is offline
post #14 of 37 Old 01-11-2011, 09:57 PM
IslandTJ
They clamp on to the frame, similar to the Jeeperman design.
IslandTJ is offline
post #15 of 37 Old 01-11-2011, 10:01 PM
Humboldt
Humboldt's Avatar
The asshat that owned my Jeep before me did this. The frame repair was a pain and knowing what I know now, I would have passed and found a different Jeep. Who welds crap below the body mounts...
Humboldt is offline
Cheap, Entry Level Rocker Guards/Rocker Panels Croce JK Wrangler Technical Forum 14 03-03-2010 08:38 AM
A to Z Rocker Guards Vs. Rokmen Rocker Guards willhbauto TJ Wrangler Technical Forum 26 03-04-2008 04:48 PM
installing rocker guard-did you drill out the flare extension nutserts? Vacant Stare TJ Wrangler Technical Forum 12 05-14-2007 10:50 AM
Rocker guard drill holes Bebop TJ Wrangler Technical Forum 6 06-18-2004 09:18 PM
no-drill rocker rails bdj428 TJ Wrangler Technical Forum 3 03-09-2004 04:31 PM
