no bu5 - JeepForum.com
post #1 of 14 Old 08-22-2007, 10:32 AM Thread Starter
wegotj
no bu5
thats the error message that came up and screwed up my whole cluster of gauges.
wat is it?
wegotj is offline
post #2 of 14 Old 08-22-2007, 12:50 PM
DeesTJ
go to the FAQ and do a search..there is a very detailed step by step guide to walk you through it...
FAQ is your friend
Colorado Jeep Club Member # 315
DeesTJ is offline
post #3 of 14 Old 08-22-2007, 01:08 PM
rjt36
rjt36's Avatar
2009 JK Wrangler
I've gotten this, too, and I looked it up and found no mention of a no bu5. I have no idea what it means. Do you have a link to it in the FAQ?
rjt36 is offline
post #4 of 14 Old 08-22-2007, 01:08 PM
BlkBird
I dont know what's wrong with your truck but going to FAQ and doing a search for "no bu5" yielded 0 results.
2004 Wrangler X 4.0
2000 Cherokee Sport 4.0
1992 Dakota Sport 5.9
1971 Pontiac Firebird
BlkBird is offline
post #5 of 14 Old 08-22-2007, 01:41 PM
rjt36
rjt36's Avatar
2009 JK Wrangler
I have a feeling its just a part of the programming, and it's nothing to be concerned about. Maybe someone will know.
There's nothing wrong with mine. I was just randomly checking for codes and it came up. I can't remember if it always did it or not.
rjt36 is offline
post #6 of 14 Old 08-22-2007, 02:24 PM
Stang_guru
"no bus" means the "bus"( used to let various modules communicate to each other and the PCM) is not working, could be a bad connection behind the cluster, or bad connector completely. i've heard there was a TSB for this problem, not 100% sure as I havnt had this problem.
if it were me, i'd pull the cluster and check all the connections behind it really well and make sure all the blades have good contact.
2005 TJ, Rockey Mountain Edition, 4.0, D44, 6-sp, Patriot Blue.
2002 Mustang GT 'Vert, 5-sp, not stock, Mineral Gray.
2001 Ranger XLT , 4.0, 5-sp, White.
Rocky Mountain Edition Club Member #5
Blue Jeep Club Member #242
Stang_guru is offline
post #7 of 14 Old 08-22-2007, 02:28 PM
rubba19
Temporary fix is to pound the top on the dash until you can get in there. Usually gets them to reconnect.
That or a big bump in the road.
rubba19 is offline
post #8 of 14 Old 08-22-2007, 02:36 PM
Stang_guru
you know, even with my certifications, ive found that through my years of expierience, that there have been very few times that i havnt been able to fix something with a heavy fist, or a BFH lol. it just works lol.
post #9 of 14 Old 08-22-2007, 03:15 PM
rjt36
rjt36's Avatar
2009 JK Wrangler
To the OP, what kind of cluster problems are you having? I got the same code, but I don't have any problems. Everything works fine, that's why I ignored it. I'm going to give it a shot in a couple minutes when I head home and see if I still get it a few weeks later.
rjt36 is offline
post #10 of 14 Old 08-22-2007, 03:18 PM
JoonHoss
2011 JK Wrangler
as mentioned, it is the connection to the guage cluster at the back, (in the dash)
it is most commonly cured by removing the cluster, very slightly 'bending' the pins outward to make better contact, and re-installing. some also use a small amount of di-electric grease...
http://www.google.com/custom?domains...D%3A1%3B&hl=en
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #11 of 14 Old 08-22-2007, 04:20 PM
DeesTJ
FAQ is your friend
"guages quit working"
just give the pins a gentle twist (careful not to break them) hasn't happened since i did the fix 3 years ago.
For the short term i used to hit the horn with the side of my fist (a couple quick/solid taps should do)
and while you're back there might as well pull the bulb for the shift light!!!!
DeesTJ is offline
post #12 of 14 Old 08-22-2007, 05:27 PM
EG00TJ
EG00TJ's Avatar
1993 XJ Cherokee
Yea i got that twice in a week about 4 months ago. never did it again...
96 ZJ Longarm
Previous rigs : 96xj , 92 xj , 00 tj , 90 xj , 93 Longarm XJ
EG00TJ is offline
post #13 of 14 Old 10-25-2007, 10:56 PM
vswv8
vswv8's Avatar
looking for ground info...my 99 xj has the no bu5 in the od..and i have already gone to a dealer and had the above mentioned sb preformed...didn't change a thing......hit the power door locks to the locked position and hold it there and every thing works,,,map lites seem dim though when you do this..but they don't fuction at all if yu don't hold the pdl in locked position...fuel gauge is the only gauge that operates after you hold pdl in locked position and release it....everything else goes dead in cluster..........
vswv8 is offline
post #14 of 14 Old 10-25-2007, 11:06 PM
jdragger
Guys - check your battery or system voltage. A little voltage drop will do this and other weird things. If things make no sense all ways check the power supply - in your computer at home and on the jeep.
jdragger is offline
