No brake/hazard lights, or turn signals... - JeepForum.com
post #1 of 12 Old 07-15-2010, 10:05 PM Thread Starter
TwistedDrum5
I know what you are thinking, and I replaced the relay thats in the steering column and nothing...
I don't get the tick tick sound and no lights on interior or exterior when I brake, or use turn signals or flashers.
I've checked fuses.
When I turn the lights on the rear lights come on, but still no brake lights.
Any advice?
CHRISTIAN JEEP member #173
TwistedDrum5 is offline
post #2 of 12 Old 07-15-2010, 11:18 PM
2kbeep
Check the grounds. Sounds like a fuse problem as well.
2kbeep is offline
post #3 of 12 Old 07-16-2010, 01:15 PM
Jonny Jeep
Jonny Jeep's Avatar
Brake lamp circuit feeds through the turn signal multifunction switch. I'm guessing the switch needs to be replaced.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is online now
post #4 of 12 Old 07-16-2010, 04:42 PM
sxysouthtx
I had the same problem about a week ago. I replaced blinker switch, then brake light switch, then I found out it was the fuse. I felt stupid, but the fuse was unlabeled. But I would check for grounds before buying a brake light switch. But never hurts to replace it. Good luck finding the gremlin.
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline
post #5 of 12 Old 07-16-2010, 07:46 PM
teflonhunter
I don't remember what they call the part but it is in the steering column. It is where all the wires that are controled from when you turn the key on. It is an elictrical and mechanical part because it has a linkage that comes from the key switch running to it. I had to replace mine awhile back. I had no radio, no blinkers, no horn , etc.
teflonhunter is offline
post #6 of 12 Old 07-16-2010, 09:50 PM
wushaw
Rockin jeep
wushaw's Avatar
Could it be a multifunction switch assy.
wushaw is offline
post #7 of 12 Old 07-17-2010, 09:44 PM Thread Starter
TwistedDrum5
Fuse under the hood?
post #8 of 12 Old 07-18-2010, 05:18 AM
wushaw
Rockin jeep
wushaw's Avatar
I've checked fuses.
Any advice?
Didn't you just say you checked the fuses????
wushaw is offline
post #9 of 12 Old 07-18-2010, 05:54 AM Thread Starter
TwistedDrum5
Yes the ones under the hood. I'm not home right now and I saw a tutorial online that showed fuses in the glove box?? Wasn't sure if those were in my jeep.
post #10 of 12 Old 07-18-2010, 05:59 AM
Jonny Jeep
Jonny Jeep's Avatar
Stop lights, turn signals and hazards all work off different fuses so check all of the following fuses.
Under the hood - Fuse 3 (brake lamps), 22 (turn signals), 27 (hazards).
Behind the glove box - Fuse 2 (brake lamps), 13 (turn signals).
It could be the grounds at the rear lamps but as both lamps are affected I'm more inclined to suspect a fault switch.
post #11 of 12 Old 07-05-2011, 06:54 PM
wstanton
SAME BOAT!
I have no emergency flashers, brake lights, or turn signals.
I replaced a bad brake light fuse...no solution. I swapped out the flasher relay on the steering column...no solution. I replaced the turn signal multifunction assembly...no solution.
I'm stumped!
wstanton is offline
post #12 of 12 Old 07-06-2011, 10:57 AM
Richd1963
Richd1963's Avatar
Does she still start?
Check all wiring harness to and from steering column, I had one come undone after some work was done under the dash, it wasn't re-connected properly and looked connected, but it wasn't making full contact and was causing issues. Good luck!
Rich G. 2005 Wrangler 4.0 6-Speed.
just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only
Richd1963 is offline
4-way flashers , brake lights , electrical problem , hazard lights
99 TJ Turn Signals & Hazard Lights shaunmfink TJ Wrangler Technical Forum 8 07-02-2010 02:15 AM
No brake lights/turn signals purplehavoc TJ Wrangler Technical Forum 0 05-09-2010 10:48 PM
Need Help, Brake lights/turn signals Bugz2oo2 TJ Wrangler Technical Forum 5 08-29-2006 02:56 AM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 09:18 PM
No turn signals or Brake lights Patton TJ Wrangler Technical Forum 1 09-10-2002 07:45 AM
