No Blower + Air bag light?? - JeepForum.com
post #1 of 8 Old 11-24-2006, 01:14 PM Thread Starter
RckyMtnTJ
I went out running errands today and when I got in my Jeep the blower wasn't working. I tried turning it on and off. I also tried adjusting settings. Then I noticed my air bag light was on. I just started to get out of the parking lot and the blower came on and the airbag light went off. Does anybody know what might cause this? They seem to be related.
Thanks in advance,
Jeff N
98 TJ with some stuff
RckyMtnTJ is offline
post #2 of 8 Old 11-25-2006, 02:02 AM Thread Starter
RckyMtnTJ
OK, it did it again after I made a pitstop after work today. This time I noticed my signal lights did nothing, my radio was out, and my rear wiper wouldn't work. This on top of the air bag light coming on and the defroster fan not blowing.
Anyone want to take a stab at how these items are related??
post #3 of 8 Old 11-25-2006, 02:17 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
check all your plug under the dash one may be loose
RnEmOvr is offline
post #4 of 8 Old 11-25-2006, 06:55 AM
jeepteejay
Clock Spring Assembly.
It was a recall for 98-99.
jeepteejay is offline
post #5 of 8 Old 11-25-2006, 04:27 PM Thread Starter
RckyMtnTJ
I have been having problems with my key needing a slight "jiggle" to get it to turn in the ignition. I noticed last night the "second" I touched the key, everything came back on. Not sure if thats a fluke chance or if it was related. I tried wiggling the key a number of times to see if it would result in it shutting things down again. It sounds likely though.
I have heard lots of people talk about clock springs in the past. However I have never known what one is. What is a clock spring? How hard is it to get at? Do they honour recalls on 8yr old vehicles??
post #6 of 8 Old 11-25-2006, 04:30 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
This sometimes happens to me, also. My whole dash goes dead, radio quits, no headlights, nothing. Pretty much all I have are gas and brake pedals. To fix, I just slam the gauge pod back and forth a few times. Usually works
If your hammer can't fix it, get a bigger hammer!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #7 of 8 Old 11-25-2006, 04:33 PM
Rocky529
Rocky529's Avatar
Disassemble your cluster, sand down and slightly bend the electrical connections on the back of the cluster. Apply some dielectric grease and reassemble. Should cure the problem for good.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #8 of 8 Old 11-25-2006, 06:05 PM Thread Starter
RckyMtnTJ
That doesn't sound like the infamous gauge cluster problem. When he says his radio goes dead and he loses his headlights. he gauge cluster problem is just everything on the dash cluster going dead.
On a side note, I don't lose my headlights. Just ability to signal.
heater/blower control light bulb southbound YJ Wrangler Technical Forum 23 11-09-2011 08:27 AM
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 09:13 PM
Intermittent Air Bag light/Blower Motor problem jjpark TJ Wrangler Technical Forum 2 04-12-2010 05:19 PM
1999 sahara (HVAC blower motor inop w/ airbag light) dustman1 TJ Wrangler Technical Forum 2 03-14-2010 12:57 PM
Help I have airbag light with fan blower inop. frost174 TJ Wrangler Technical Forum 2 07-01-2008 03:13 PM
