No air from defrost - JeepForum.com
post #1 of 3 Old 08-22-2010, 08:59 AM Thread Starter
CoyoteIrons
No air from defrost
I have this problem with my defrost that I would like to fix before it gets cold out. When I turn on the defrost air will come out on the first two blower settings but when I turn it higher than that I can hear what sounds like the door inside the vent closing and no air comes out. It will stay like this until i turn all the vents off(sliding the control all the way left). All other vents work like they should and the heat and "cool" works. Is that little door inside there vacuum actuated or does it have some mechanical linkage to open and close? I'll be tearing apart the dash tomorrow to fix it if there isn't an easier way to do it. Thanks JF!
CoyoteIrons is offline
post #2 of 3 Old 08-22-2010, 11:10 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Check for a vacuum leak in the lines under the hood and behind the glove box.
TheBoogieman is offline
post #3 of 3 Old 08-23-2010, 10:22 AM Thread Starter
CoyoteIrons
Found the problem, the linkage from the vacuum actuator to the flapper was broke. Some JB weld and the problem is fixed for now, until it breaks again.
I only have defrost, nothing else.. 05LjNj TJ Wrangler Technical Forum 4 03-03-2010 05:17 PM
defrost only 2005X TJ Wrangler Technical Forum 4 06-15-2009 01:29 PM
AC blows when I have defrost or defrost/feet selected Marholmes44 TJ Wrangler Technical Forum 2 01-18-2009 06:18 PM
94 YJ No Defrost jmichel62 YJ Wrangler Technical Forum 4 07-10-2006 05:37 PM
Defrost CTMpwrdcamry TJ Wrangler Technical Forum 3 12-17-2004 06:44 PM
