No 3rd brake light won't pass inspection? - JeepForum.com
post #1 of 31 Old 01-31-2011, 09:04 AM Thread Starter
RVA_TJ06
I haven't had one on in years. My tire carrier doesn't have a spot where the factory could have fit. I had a guy doing my state inspections but no longer in the area. Took it to the dealer and they said it won't pass without the brake light. Anyone have an ideas on a 3rd brake light option? I was thinking of
and fitting it into the lower valence of the tailgate.. Anyone have any ideas?
Finally paid off...
RVA_TJ06 is offline
post #2 of 31 Old 01-31-2011, 09:12 AM
Contra
bummer. they are not required to pass here in my county, I do inspections as well
post up a pic of the rear of your jeep and we will try to give you ideas
Ever Gone Geocaching?
Contra is offline
post #3 of 31 Old 01-31-2011, 09:16 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
As long as it is the proper height and connected to the brakelight power circuit almost any red light will do. Mine is made from a foam cupholder and a trailer LED. It fits in the center of the spare tire.
Whybu1 is offline
post #4 of 31 Old 01-31-2011, 09:18 AM
Rubikahn
Rubikahn's Avatar
Here's a link to a write up for a very clean looking install. http://www.jeepforum.com/forum/f140/...illing-452469/
OME ZJ/LJ lift, 33" MT MTZ on AR-23 wheels, front and rear JKS trackbars, 1" seat risers, MORE 1" BL and MML, factory Ipod adapter. Light khaki jeep club #72
Rubikahn is offline
post #5 of 31 Old 01-31-2011, 10:04 AM
stuff2c
i have one in the center of my wheel as well... fairly simple once you get a round lite. only down side is i can't use my bike carrier anymore, it had a permanent piece that stuck out though the hole . that reminds me i need to find a hitch one on Criagslist
Thanks to the interstate highway system... most people don't see nut'n in the USA.
stuff2c is offline
post #6 of 31 Old 01-31-2011, 10:28 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
$3 Advance auto light held in place with silicone just to pass inspection in that dreaded Va state and their inspections.
TheBoogieman is offline
post #7 of 31 Old 01-31-2011, 10:56 AM
Best4x4
Go somewhere else besides the dealer. The reason they said you'd fail was because they know it came with a 3rd brake light. Go to an independent inspection place where they don't know Jeep's all that well. Worth a shot anyways.
I know it worked for a friend of mine. He had a YJ Body on a TJ frame and they would have had to run an OBDII test on it since it's an 05 TJ really (CEL light is on due to some YJ/TJ modifying). He went to an independent inspection place and they didn't run an OBDII test on it because they thought it was truly was YJ (with coil springs all the way around it lol).
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #8 of 31 Old 01-31-2011, 11:10 AM
Whybu1
Whybu1's Avatar
Third brake lights have been around to long for a place to "not know".
Whybu1 is offline
post #9 of 31 Old 01-31-2011, 11:15 AM
MONSooNmonkey
In pa you only need 2 brake lights so if one goes out you can still pass inspection but they will tell you yuh need to replace the light bulb. Its more of a back up just incase than anything.
Sadface :(
MONSooNmonkey is offline
post #10 of 31 Old 01-31-2011, 12:32 PM
VTJeePTJ
Yep I failed in VA one year for no 3rd brake light. Rigged up a temp light to get it pass then took it back off. Took it to a different place last two years in a row and passed without it (knock on wood). Either way, it shouldn't be too difficult to rig up something temporary (or permanent). Tractor supply has a pretty good variety of different size LED lights that should work fine if you find a way to mount it. With my tire carrier, I just used a round LED that fit in the hub area of the spare wheel where the center cap would normally go. Worked fine but I eventually pinched the wires and haven't wired it back up since then.
2003 Jeep TJ- 4" Nth LA, 4.88/ARBs, Rubicrawler, 33's, Savvy Steering, Poison Spyder Armor, etc.
VTJeePTJ is offline
post #11 of 31 Old 01-31-2011, 12:37 PM
Whybu1
Whybu1's Avatar
Code actually only addresses the two side brake lights (both must work)
(e) Other required lamps. A vehicle specified under this subchapter shall have at least one red stop lamp on each side of rear of vehicle, which shall be illuminated immediately upon application of the service brake. http://www.pacode.com/secure/data/06...5/s175.66.html
Then again further down the code is the following vague statement about lights:
(9) Check the lamps and lenses and
REJECT IF one or more of the following
apply:
(i) An exterior bulb or sealed beam, if
originally equipped or installed, fails
to light properly, except ornamental
lights.
A missing third brake light would obviously "fail to light" so...
Whybu1 is offline
post #12 of 31 Old 01-31-2011, 01:06 PM
stuff2c
we just put every piece of ***** that rolls on the roads here in floriduh. just lucky i guess
stuff2c is offline
post #13 of 31 Old 01-31-2011, 01:26 PM
MONSooNmonkey
apply:
lights.
Yeah but not many inspection garages here are to the letter. If it isn't insane and it is safe you are good to go, if you do something retarded then you have an issue. IE: cutting off your roof to your cherokee haha.
As for the 3rd light, I have never had one burn out (knock on wood) but they look at the main lights. The 3rd light is more of (I have 3 brake lights and your ******* didnt' see any of them?!?!) kind of thing. If it fails to light or wasn't present when the vehicle left the factory there is nothing to worry about.
Sadface :(
post #14 of 31 Old 01-31-2011, 01:52 PM
rob78
I ended up with a Delta 3rd brake light.
Kind of a pain in the *** griding down the fittings so it would work in the lug holes of a Moab wheel, but they do work and are unobtrusive.
rob78 is offline
post #15 of 31 Old 01-31-2011, 02:06 PM
john NC
john NC's Avatar
just get a 2" or whatever size light it takes to fit in your spare where the center cap goes from an auto parts store, mine was a trailer light i think. drill a hole in the factory spare tire carrier for the wire. solder or crimp the wires from the original 3rd brake light to that, stick it in the spare tire, and you should be good to go.
it's passed inspection 3 times
john NC is offline
pass rear brake light doesn't work/ right blinker blinks fast Hwkscr TJ Wrangler Technical Forum 5 10-24-2010 07:03 PM
will i pass nj inspection? joeYJeep95 TJ Wrangler Technical Forum 0 09-17-2009 08:50 AM
Third brake light...inspection failure? Rio-Bravo TJ Wrangler Technical Forum 10 10-04-2007 11:38 AM
i can't pass NYS inspection...help nyconickk TJ Wrangler Technical Forum 17 05-04-2005 01:48 PM
Third brake light NJ inspection Pipsqueak YJ Wrangler Technical Forum 6 04-21-2004 04:50 PM
