Quantcast Newly installed used 32rh already busted! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Newly installed used 32rh already busted!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 03-14-2009, 06:34 PM   #1
JeepinTim
Today I took my jeep out for a spin at Reiter Pit and was having a blast. Going over rocks, driving up steep inclines, splashing around in puddles. Ya know, the good stuff.
Well, we decided to go up a trail that we skiped over and soon we added some light snow wheeling into the mix... as we were driving up this fairly simple road with minor amounts of slush, I heard a sound that was very similar to having the steering wheel cranked all the way over, but deffinatly not coming from any steering components.
So I pull over to see what the heck was up! I look under the jeep, and there smoke coming from near the oil pan. I then take notice to lots of wonderful red ATF on the ground under my jeep. I'm believe it leaked from near the bellhousing onto the exhaust pipe.
This transmission was installed in august and has less than 5k on it! I'm so confused as to how this happened, especially since I'm really careful about using the skinny pedal. I mean I have 3.07 gears and 30 inch tires for crying out loud!
I managed to drive the 80 miles home, but the trany refused to "lockup" at highway speeds, but aside from that it seemed alright in 3rd. First and Second gears are hit or miss (I had to manually downshift at lights), and now my engine temp goes above 210 when I stop at a light. I'm assuming its related.
So for now, my jeep will remain parked untill I can call the dealership on monday and see why a new trany like this would fail so quickly!
If anyone has some ideas as to what may have happened.. I'd really appreciate it!
"Life is not about sitting around doing the same **** over and over. Get out there and do something!"
JeepinTim is offline   Reply With Quote
Old 03-14-2009, 06:51 PM   #2
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Sounds like torque converter took a dump? Definitely take it back to the people that did the rebuild! Was a new torque converter installe on the rebuild?
GOLENJEEPTJ is offline   Reply With Quote
Old 03-14-2009, 06:54 PM   #3
Nonya
It overheated and dumped some fliud out...refill it
Nonya is offline   Reply With Quote
Old 03-14-2009, 06:55 PM   #4
GOLENJEEPTJ
You definitely have some serious problems!
Old 03-14-2009, 06:57 PM   #5
GOLENJEEPTJ
And how did it over heat through that scenario?and dump fluid out at the front of trans?
Old 03-14-2009, 06:57 PM   #6
Ironwind1972
Look for a crack or hole, those aluminum cases aren't that strong when hit by a rock or log.
Ironwind1972 is offline   Reply With Quote
Old 03-14-2009, 07:01 PM   #7
JeepinTim
They didnt rebuild it, my used car warrenty wanted them to buy another transmission that was rebuilt already. I got it with 60k miles. As for the Torque converter... I have no idea!!
Old 03-14-2009, 07:01 PM   #8
GOLENJEEPTJ
How much fluid was lost?
Old 03-14-2009, 07:03 PM   #9
GOLENJEEPTJ
So it wasn't a brand new trans like on your original post.That will change everything! Why do you post brand new trans already busted?
Old 03-14-2009, 07:05 PM   #10
JeepinTim
Here's the real kicker, almost no fluid is missing from the dipstick! What the heck!
I think it was just a little ATF burp though. The fluid dosn't look burnt, but it does smell like tires though...
Old 03-14-2009, 07:06 PM   #11
JeepinTim
Sorry, I should have said new to me. I'm just a little miffed right now cause my dang jeep bleed red stuff all over the trail!
Old 03-14-2009, 07:10 PM   #12
GOLENJEEPTJ
That is a bummer!First thing I would do would be to contact your warranty company.Bottom line is... it's a used tranny.Maybe they will make good on it this time around, beings you only have 5Kmiles on it!
Old 03-14-2009, 07:12 PM   #13
JeepinTim
Yeah man, but it's jeep dealership installed too. I've also already gone through a trany on this warranty! UHG.
Old 03-14-2009, 07:34 PM   #14
GOLENJEEPTJ
Good luck,keep us posted on results.
Old 03-14-2009, 08:52 PM   #15
Nonya
The overflow is in the frt thats why you say all the fluid dump out there. Check the level with the engine running and trans in N....fill it up and see if it drives ok. If it does forget about it.....overheating the fluid isn't that hard to do.
Glock Forum
