Newly installed U Joints seem stiff.... - JeepForum.com
post #1 of 11 Old 05-20-2009, 08:37 AM Thread Starter
davenay67
I am in the process of replacing all of the U joints in the front driveshaft. After installing the U joint at the front of the driveshaft, it seems stiff to move by hand. It's not notchy or anything like that, it just seems to take a bit of effort to move by hand.
Is this normal..?? Would it feel better if it were attached to the front axle and then moving the driveshaft..?? Is this expected when first installed, will it loosen up, or settle a bit when run for a few miles..??
The replacement job went (apparently) smoothly, quickly and relatively easily. I just want to make sure that everything appears fine and normal.
Cheers.
Dave.
2.5L 4 banger, 5 speed AX-5,
NP231,
RC 2.5" lift,
31x10.5 tyres
Low Output 4 Cylinder Jeep Club #138
187,000 miles and counting....
davenay67 is offline
post #2 of 11 Old 05-20-2009, 08:42 AM
Noxian
2011 JK Wrangler
Sounds normal, they might need to break in, and for the grease to warm up abit before they move freely.
Noxian is offline
post #3 of 11 Old 05-20-2009, 08:47 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Cheers.
Dave.
Did you set the caps back against the snap rings?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #4 of 11 Old 05-20-2009, 08:56 AM Thread Starter
davenay67
I did indeed do this. Is it possible to set the caps too far in to start with, and would they seat themselves over time if this were the case. Given the tight tolerances of the U joints, I can't see there being a lot of margin for error here..??
Not knowing how newly installed joints should feel, I am being cautious on the first timne around. The fact that all the joints feel the same is either a sign that things are fine, or I was able to screw up the job equally on all 3 U joints....!!
Dave.
NP231,
RC 2.5" lift,
31x10.5 tyres
post #5 of 11 Old 05-20-2009, 09:02 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Dave.
There's not a lot of tolerance, nor can there be. If it's off even slightly, the shaft will not be spinning on centerline and will vibrate itself to death in short order.
So, from too tight and binding on the ends of the pins to just right is not discernible to the naked eye. Just tap below the yokes to set the caps back and if it moves freely, it's likely good to go.
I am Savvy
mrblaine is offline
post #6 of 11 Old 05-20-2009, 09:10 AM
tavic
2010 JK Wrangler
Just to be safe, I'd take the U joints back off and double check that none of the needle bearings have gotten dislodged. If all looks good, you're good to go.
tavic is offline
post #7 of 11 Old 05-20-2009, 09:12 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
No need. You can't get the snap rings in if one of the needles has fallen over.
I am Savvy
mrblaine is offline
post #8 of 11 Old 05-20-2009, 09:14 AM Thread Starter
davenay67
Thanks for the replies so far guys.
I am going to try gently tapping around the yokes tonight and see if this has any effect on the feel of the installed joints....
Dave.
NP231,
RC 2.5" lift,
31x10.5 tyres
post #9 of 11 Old 05-20-2009, 11:35 AM
lupinsea
lupinsea's Avatar
One thing I do after installing a new u-joint (or re-installing a joint) is to take a steel mallet and give the yoke shoulders a couple swift, firm smacks. Tends to get everything set right with the u-joint caps and reduce any binding that might be there from pressing the joint caps in. So far this has worked beautifully for me and I believe it's actually mentioned in the FSM as an "official factory u-joint installation procedure".
- Jay
lupinsea is offline
post #10 of 11 Old 05-20-2009, 04:40 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
x2...
Knuckelhead is offline
post #11 of 11 Old 05-21-2009, 07:07 AM Thread Starter
davenay67
I did exactly this on both the U joints installed so far. The one at the transfer case end (CV joint) freed up beautifully and is now as smooth as butter. The other one at the front differential end was still stiff though.
Given that I have the HF tool, joints are a real easy job to remove/install, so I took out the stiff U joint and re-installed it. No difference, still a little stiff after the second install also. It is perfectly fine until the very last push needed to actually get the snap ring located in the groove.
I now actually know it's a little on the stiff side. Not sure how big a deal this is at this point, and not sure how to proceed. I'm wondering if it's worth it trying a new U joint in there to see if that makes a difference..??
Dave.
NP231,
RC 2.5" lift,
31x10.5 tyres
Newly installed soft top reetbeck JK Wrangler Technical Forum 5 06-30-2008 08:05 AM
Get Vibration from newly installed 4:56 gears ? fubar5150 YJ Wrangler Technical Forum 13 09-28-2007 09:39 PM
picture of newly installed 8.8.. Goondock TJ Wrangler Technical Forum 8 01-08-2007 08:40 AM
What paint is best/affordable for my newly installed 8.8? quitelifted TJ Wrangler Technical Forum 4 08-15-2006 08:23 AM
Help! Newly installed M.O.R.E. Mounts jwbogger TJ Wrangler Technical Forum 11 11-25-2004 05:54 AM
