newer seats in older TJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > newer seats in older TJ
Poison Spyder from CCOR!HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-18-2009, 08:07 AM   #1
kswyg001
2010 JK Wrangler
I have a 2000 Wrangler SE and my seats are done. I found a deal on some 03-06 wrangler seats.
So- will the 03-06 seats bolt right up to my jeep?
Anyone done this? Pics?? Color recommendations? Thanks a lot everybody.
kswyg001 is offline   Reply With Quote
Unread 11-18-2009, 08:24 AM   #2
kloppk
I put some 03 TJ seat into my 97 TJ (same shot seat problem).
The only minor issue was I needed to drill a new hole in the rear most part of the seat risers to get the last seat mounting bolt of the seats to line up with the risers.
kloppk is offline   Reply With Quote
Unread 11-18-2009, 10:08 AM   #3
kswyg001
2010 JK Wrangler
thank you, that shouldn't be a problem at all to drill a new hole. any more opinions?
Unread 11-18-2009, 12:05 PM   #4
r_unda
r_unda's Avatar
I installed 2004 seats in my 98 TJ. The front ones just bolted right in, for the rear seat I drilled some holes for the rear brackets.
Originally Posted by r_unda View Post
Back seat rear bracket next to the new holes I drilled
http://i862.photobucket.com/albums/a...3/DSCF0424.jpg
Bracket in place with bolts
http://i862.photobucket.com/albums/a...3/DSCF0425.jpg
Under the body; plenty of room after body lift to tight the nuts
http://i862.photobucket.com/albums/a...3/DSCF0426.jpg
All finish!
http://i862.photobucket.com/albums/a...3/DSCF0427.jpg
Hope this helps if someone else is thinking on installing newer style TJ seats in an older TJ
r_unda
My Jeep isn't getting older, it's getting newer part by part
2007 WK CRD 4x4 Limited -GDE Hot Tune - SMRP
1998 TJ SE (Modified)
1973 CJ5 (Hers)
1951 Willys truck (Work in progress, very slow progress)
r_unda is offline   Reply With Quote
Unread 11-18-2009, 12:20 PM   #5
kswyg001
2010 JK Wrangler
info is looking good so far. i'm only replacing the front seats because the back one rarely gets used.
Unread 08-02-2011, 11:49 AM   #6
dougiefresh131
I'm in the middle of doing this. 04 seats into my 01. i drilled the holes for the seat risers, everything fits. my only question is where do I attach the seat belt to? I took it off the 01 and i cant seem to find a place to bolt them up on the 04. suggestions?
dougiefresh131 is offline   Reply With Quote
