Newbie needs help - JeepForum.com
post #1 of 7 Old 12-26-2007, 07:48 AM Thread Starter
meketawj
Newbie needs help
Jeep Geniuses,
I have a some questions that you can answer:
1) I just got my TJ and it has 4" suspension and 2" body lift. It is running on 33x14.50x15 tires on 15x12 rims. When it hits the highway it wonders all over the road, and requires alot of counter steer. What is wrong and how do i fix it? Is it the tire and rim size?
2) If I get tires and rims, I would like to stay 33" tire and 15" rim. What is the best for the weekend off road daily driver? 33x12.50x15 on 15x8, 33x12.50x15 on 15x10 or 33x10.50x15 on 15x8? What do you guys think?
I am new at this and looking for a little help. Thanks alot
meketawj is offline
post #2 of 7 Old 12-26-2007, 07:53 AM
robncar
robncar's Avatar
I'm not a genius (was tested at 147 once, but that was when I was much younger, though my kids seem to know everything ), but I did stay in a Holiday Inn Express last night...
1. I'd start with making sure everything on the front end is tight and in good shape. Make sure that the draglink and trackbar mounts are parallel (no drop pitman arm). Then, perform a front end alignment. All you can really do is toe-in and can do it yourself with a little time and a couple simple tools:
http://www.4x4xplor.com/alignment.html
or
http://www.stu-offroad.com/steering/align/align-1.htm
2. I think I'd go with the 33x10.50x15 on 15x8. It'll be better for gas mileage (slightly) and make it easier on the engine and brakes.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 7 Old 12-26-2007, 08:10 AM
flexytj79
i had 33x12.5r15 on 15x10 and it drove fine ,make sure you use a radial tire
Originally Posted by ram1500dodge View Post
holy bejesus, look at the size of that winch hook
Originally Posted by bmlawless View Post
This should be interesting. Aussies always come up with the best stories.....
Originally Posted by Rubicon 05 LJ View Post
Better yet, why are you looking at the hook??
shes cute an all, but man, if my hook looked like that hook, id never let it out of my sight.
flexytj79 is offline
post #4 of 7 Old 12-26-2007, 08:12 AM
dragginwagon406
When I bought mine it drove the same way. 4" Trail Master lift and they had installed a dropped pitman arm without relocating the track bar mount.
I would check that too.
The dropped track bar bracket I'm referring to bolts on to the factory frame mount and adds a second attachment point like below.
http://www.4wdandsportutility.com/te.../photo_04.html
http://www.4wdandsportutility.com/te.../photo_22.html
This shows the difference in the pitman arms,
http://www.jeepforum.com/forum/f9/tj-build-one-step-time-full-width-axles-494040/
dragginwagon406 is offline
post #5 of 7 Old 12-26-2007, 08:31 AM
slo9fo5oh
Some of the afore mentioned things too, but, that is a very wide tire. How are your roads, are there any "ruts" even the slightest indentations where the normal wear on the road is, can/will make those heavy wide tires on your light jeep wander a bit as the tires are kinda fighting eachother to be in the lowest part of the rut. Does that make any sense? Like mine, I have 35/12.50's, on smooth newer roads that arent worn too bad here in Jax, my jeep is great, but some roads that have the ruts worn in, it makes mine wander a bit too.
slo9fo5oh is offline
post #6 of 7 Old 12-26-2007, 09:41 AM
fordfreak$
I agree...tire is super wide. This is probably your reason. GEt a 15X8 rim. I run a 33X12.50.R15 on a 15x8(BFGMTZ's) and didn't have that problem. Recently I changed to my "other tires"(GYWranglerMT's) the same size but with a much "squarer" tread pattern, and now it wonders everywhere. I wish I had kept the bald BFGs because they rode better all around on and off-road.
2000 TJ, Clayton and Ford 60's
BOFA Racing
fordfreak$ is offline
post #7 of 7 Old 12-26-2007, 12:07 PM
richs347
Also make sure the tire pressure is correct for the weight of the vehicle. If you're running 32psi on 33's with a Wrangler your probably riding on the center of the tire. Experiment, but it should be about 25-26psi.
'05 Rubi Unlimited, RE 4.5 Springs / Adj arms, JKS body lift, RE Shocks, Jeep Medic Engine Skid, Rokmen Belly Up and gas tank skid, AtoZ Rockers, Bestop tire carrier and rear bumper, 4" Xenon flares, 35" MTZ's, custom front bumper, etc...
'99 Cherokee Sport, 5spd, 231, 8.25" rear, RE 3.5" lift, 31's
richs347 is offline
Newbie Jeep owner w/ a newbie Jeep question bigjim72 YJ Wrangler Technical Forum 12 08-21-2009 09:46 AM
A Newbie introduces himself and asks Newbie questions--film at 11. Copywriter TJ Wrangler Technical Forum 8 09-24-2004 12:20 PM
Newbie. pparekh TJ Wrangler Technical Forum 4 04-30-2004 04:56 PM
Another Newbie.... Nauset TJ Wrangler Technical Forum 2 04-30-2004 10:46 AM
Newbie...Greetings all 4TheGoodTimz TJ Wrangler Technical Forum 11 03-31-2004 06:00 PM
