Newbie needing advice - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Newbie needing advice
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 10-31-2008, 01:53 PM   #1
Rendy
I am planning on heading to Uwharrie tomorrow and although its not the first time ive been trail riding it will be the first time I will be riding some decent trails. I am still new to riding trails and am wondering if it will be worth it to disconnect my swaybar. I know it will benefit me obviously, but seeing as how i have never disconnected the links and my suspension is stock i am wondering if i should or just get quick discos and take em off next time. Ive got like an hour drive to uwharrrie and I dont really know if i should risk taking em off and not getting them back on for the ride home. What is my best bet?
1998 Flame Red TJ
2.5L 4cyl
http://www.facebook.com/profile.php?id=1396410147
Rendy is offline   Reply With Quote
Unread 10-31-2008, 02:06 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
You can easily temporarily disconnect your front (leave the rear connected) antiswaybar in just a few minutes, and it's just as easy to reconnect it before you drive home. Just use a torx adapter for your ratchet drive for the bolt head (T-50 perhaps? I forget the size now) and a wrench to disconnect the lower part of both anti-swaybar link from the axle. Then use a bungee cord or zip tie to secure the links up and out of the way, passing the cord or zip tie through the little opening where the upper suspension spring bucket support is welded in place, in front of the upper coil spring bucket. Even if you didn't get them reconnected for the drive home, you'd be fine so long as you drove it like a Jeep and not a sports car.
Disconnecting/reconnecting only takes about five minutes, I used to do the same thing and it worked very well until I finally installed quick disconnects for the front antiswaybar.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 11-01-2008, 12:20 AM   #3
Rendy
thanks jerry yea i just didnt know how simple it would be to get it reconnected.....i hope its not too rusted because i dont have any pb blaster to ease my pain.....i suppose ill just see tomorrow
1998 Flame Red TJ
2.5L 4cyl
Unread 11-01-2008, 12:43 AM   #4
willness33
Enjoy the dust at URE.
willness33 is offline   Reply With Quote
Unread 11-01-2008, 01:13 AM   #5
Jeepster83
youll be very surprised at how the Jeep does with stock suspension and the front disconnected. take pics and have fun!
its either a T50 or T55 torx bit. i dont remember for sure though. if you dont have one your local parts store should let you test fit it before you buy it.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline   Reply With Quote
Unread 11-01-2008, 01:22 AM   #6
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
As Jerry said - T50 (or T55?) and a wrench and you'll be on your way! It's definitely worth it to remove the links for the trip - you'll be amazed at the difference...
COTM - October 2012! - It's for Sale! - Click Here!
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Unread 11-01-2008, 01:29 AM   #7
JeepinRRT
it is a T-55 torx bit pick up one with a 1/2 drive adapter and you will be all set. If you on level ground they are prety easy to bolt back in. good luck and have fun
03 TJ silver, 4.0 5 speed, RC 3.25" lift, JKS 1.25" BL, 1" MML, RC 2.2 Steering stabilizer, 33x12.50 BFG AT T/A KO's, 15x8 MB Razor Wheels
Optional D44 rear
Custom switches in sound pods for when doors are off
JKS Disco's, Infinity's in the pods
JeepinRRT is offline   Reply With Quote
Unread 11-01-2008, 04:14 AM   #8
Skyryder
If it's not too late, like you left all ready, take 'em off at home, oil them up,
and reinstall for the ride there. Then you'll have no surprises (rusted on) when you get to the trail.
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline   Reply With Quote
