New Trackbar Frame Mount -- opinions welcome - Page 3 - JeepForum.com
post #31 of 31 Old 07-23-2010, 09:30 PM
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by MisfitSeven View Post
so what is your uptravel to downtravel ratio now?
6.5" now since I changed my spring spacers/lift height.. originally it was 5.5" up and 7.5 down on the front.... as blaine mentioned, the control arm angle becomes a problem in a hurry, especially with short arms and if there's no locker to help it climb. short arms end up getting shoved back untill the shocks are fully extended before it'll climb but it does sand dunes and jumps like a caddi on the fwy.
My rears are 13.875" travel and are a hair under 7" uptravel.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
trackbar , trac bar , mount , advice , opinion , tj , wrangler , axle , position
Wrangler front mount, frame mount, receiver hitch BLESSEDBYGOD Wrangler General Discussion 2 09-12-2009 08:00 AM
Drilling out front trackbar frame mount ROUGHSHOD TJ Wrangler Technical Forum 22 02-05-2008 06:58 PM
Trackbar Frame End torque? powerstroke01 TJ Wrangler Technical Forum 1 09-02-2005 10:27 AM
Rock rails/sliders...which is better? Frame Mount or Body Mount Sparty TJ Wrangler Technical Forum 33 08-22-2005 06:58 PM
Adj. trackbar opinions wanted Blues61 TJ Wrangler Technical Forum 9 07-01-2004 07:24 PM
