New Trackbar Frame Mount -- opinions welcome - Page 2 - JeepForum.com
post #16 of 31 Old 07-22-2010, 04:08 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Knuckelhead View Post
Fulcrum lever principle applies, longer arm makes for more leverage?...
Precisely.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #17 of 31 Old 07-22-2010, 04:13 PM Thread Starter
-dirt-
Anyone care to explain for the slow kids?
Are we saying a 5/8" bolt in the narrow 2" JJ is OK?
-dirt- is offline
post #18 of 31 Old 07-22-2010, 04:48 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i would assume so, since Currie uses them on their JK track bars...
linky: Currie Enterprises CJ Axle Parts
now the problem is you'll have a very difficult time swinging a straight bar past the diff cover...you need a straight bar/bung to thread that joint into...unless you use their bare weldable housing and bend the bar from there....or find that magical spot where a straight bar works (but is that even possible with a aftermarket diff cover, stock pitman arm, 13" collapsed length shocks, stock bumpstops and no major interference issues?).
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #19 of 31 Old 07-22-2010, 04:59 PM Thread Starter
-dirt-
If my math is correct, it looks like using the narrow JJ will save ~1" in width overall for this set-up. Is that enough to help?
Why use a straight bar?
Does TNT use Currie JJs or hemis?
-dirt- is offline
post #20 of 31 Old 07-22-2010, 05:07 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Here's what I know to be true because I just finished it.
The Savvy Unlimited runs the Currie 4" lift with their standard bumpstops. The upper is not much larger if any than the stock bumpstop and the bottom is roughly 2.5".
Gerald ordered up the Fab 9 front housing and the center section is very large. I also checked the D-30 front we removed and it was stuffing high enough that the spring perch was by passing the JJ barrel by 1" above the lower edge. It still does with the Currie Trackbar and bumpstops.
At full droop, I was dropping the front springs out of the upper perches by 2.5" because I modified the shock mounts and stopped them from binding on the arms. So much so that I installed limit straps to only let the springs drop until they just come loose in the perches.
Point being, a vertically mounted single shear JJ trackbar will do quite nicely for 98% of us, even with an over large front pumpkin.
I am Savvy
mrblaine is offline
post #21 of 31 Old 07-22-2010, 05:09 PM
Unlimited04
1. every little bit helps give you more flexibility
2. stronger. bend = higher chance of bending more when you don't want it to.
3. call and ask, get more info...it looks like a flex joint of some type of the axle end, and a poly bushing? but their only pic is also a highsteer setup with their truss....so who knows....call and ask.
any pics of these steps & shock mounts? sounds like you've got 2.5" bumpstop extensions in comparison with a stock unmodified bumpstop & 13" shocks (us 2.5" lift guys)? as mudb8's pointed out, 4" of lift & 2"+ bumpstops can keep the Currie & JKS bar off most diff covers.
Useful Write-Ups:
Funny:
post #22 of 31 Old 07-22-2010, 05:15 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
There may be some in the Test Mule thread, but a 35" Kevlar MT/R on a 15x8" rim rubs the bottom of the stock fender cut-out.
I am Savvy
mrblaine is offline
post #23 of 31 Old 07-22-2010, 05:17 PM
Unlimited04
did you have to pull the axle housing back toward the driver to clear the track bar/diff cover?
Useful Write-Ups:
Funny:
post #24 of 31 Old 07-22-2010, 05:30 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The 35" tire clears at full turn both directions.
I am Savvy
mrblaine is offline
post #25 of 31 Old 07-22-2010, 11:07 PM
mudb8
want it rite or rite now?
mudb8's Avatar
I'm actually using 2" JJ's for a TJ prototype I'm working on to clear Riddlers with stock suspension/bumpstop extension, it's not verticaly mounted and won't use a DPA nor shorten the Bar. The Currie and JKS bars I have here were binding the JJ quite a bit before the right side OME N66L shock made it to full extension.
the only 10mm bolts I've ever snapped on the axle end, were done with a socket on them in the process of installation....
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #26 of 31 Old 07-22-2010, 11:31 PM
mudb8
mudb8's Avatar
this is some shock mounts I modded recently, the purpose was to use the 11" travel OME N66L shock with Rancho 2.5" springs on stock bumpstop extension. It prevented the springs from unseating and added 2" uptravel... the rancho coils are pushing the limits of coil bind with 3/4" spacers, I compressed them with the bench mounted strut compressor and measured to find out how short they can go.
I'm using AEV highline fenders and building for 35" tires, so a custom track bar is in the works to clear the Crane cover. in it's current state the Currie won't even bolt on the frame end @ full compression due to diff interference with 16" lowers and 15" upper CA's.
I'm wondering what the unsprung length of the Currie 4" coils are since I have 13" travel shocks up front on mine running 2" stops Rancho HD2.5" coils w/2" spacers only on the front and just barely unseat the coils.
mudb8 is offline
post #27 of 31 Old 07-22-2010, 11:36 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I let the arm length and angle determine the droop. At around 12" of travel, I looked at the arm angle at full droop, decided it was way too much to be of any use and put limit straps on to drop it back to around a little under 11".
I am Savvy
mrblaine is offline
post #28 of 31 Old 07-23-2010, 08:35 AM Thread Starter
-dirt-
Does this prototype involve removing the stock frame mount? Or is there a bracket involved that attaches to the stock mount?
-dirt- is offline
post #29 of 31 Old 07-23-2010, 09:38 PM
mudb8
mudb8's Avatar
I agree with that... most of the gained travel with the 13" shocks was used as uptravel...
It'll involve removing part of the stock mount and a weld on bracket..... as of now anyway, I'm always coming up with different idea's.
mudb8 is offline
post #30 of 31 Old 07-23-2010, 10:10 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
so what is your uptravel to downtravel ratio now?
Mail crawling.
MisfitSeven is offline
trackbar , trac bar , mount , advice , opinion , tj , wrangler , axle , position
Wrangler front mount, frame mount, receiver hitch BLESSEDBYGOD Wrangler General Discussion 2 09-12-2009 09:00 AM
Drilling out front trackbar frame mount ROUGHSHOD TJ Wrangler Technical Forum 22 02-05-2008 07:58 PM
Trackbar Frame End torque? powerstroke01 TJ Wrangler Technical Forum 1 09-02-2005 11:27 AM
Rock rails/sliders...which is better? Frame Mount or Body Mount Sparty TJ Wrangler Technical Forum 33 08-22-2005 07:58 PM
Adj. trackbar opinions wanted Blues61 TJ Wrangler Technical Forum 9 07-01-2004 08:24 PM
