New thermostat & now "Check Engine" light - JeepForum.com
post #1 of 8 Old 12-31-2013, 06:03 PM Thread Starter
MLaborde
Got in late this afternoon & put in my thermostat with new gasket, & bled the air out of the system. At some point during the warm-up/bleeding, the CEL came on.
I've disconnected the battery and will reconnect in the morning to see if it stays on. I will update the thread with results in the morning.
I've replaced this t-stat 2x but this is the 1st CEL I've had. Ideas?
MLaborde is offline
post #2 of 8 Old 12-31-2013, 06:12 PM
JBTJ
Only needs to be disconnected for a few minutes. Can't imagine why you would have a CEL with what you did. Are you sure all electrical connections are made?
JBTJ is offline
post #3 of 8 Old 12-31-2013, 06:17 PM Thread Starter
MLaborde
I disconnected the temp sensor plug while I was working but I've done that every time. It plugged back in fine.
MLaborde is offline
post #4 of 8 Old 12-31-2013, 06:20 PM
JBTJ
Go connect the battery back up and see what happens. It's been disconnected long enough now.
JBTJ is offline
post #5 of 8 Old 12-31-2013, 06:31 PM Thread Starter
MLaborde
Just did. All clear so far.
Letting it warm up to check for leaks again while I'm out here in tbe cold already.
Thanks for the help the last couple of days. Much appreciated!
MLaborde is offline
post #6 of 8 Old 12-31-2013, 06:34 PM
JBTJ
No problem, hope you got it fixed this time. Don't freeze to death.
JBTJ is offline
post #7 of 8 Old 12-31-2013, 09:49 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you cycled the key to the RUN position with the temp sensor unplugged, you will throw a CEL that will go way after a few start cycles.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #8 of 8 Old 12-31-2013, 10:00 PM Thread Starter
MLaborde
I'm sure thay was probably what I did. Good to know for future reference. Thank you!
MLaborde is offline
