New Steering Column, how to remove key lock cylinder without key - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > New Steering Column, how to remove key lock cylinder without key
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 03-18-2009, 09:34 PM   #1
chem57guru
Hi all,
I bought a steering column to replace my old one and I didnt think about asking the previous owner to remove the key lock cylinder and I did not receive the original key either, so I cant do it myself. My question is, can I remove the key lock cylinder on the new steering column without the key? The only thing that I can think of is to grind down the locking tab with a dremel. While this would work I am looking for a little quicker option than sitting there for half an hour and grinding it down.
Thanks for all the help.
Paul
I describe myself as an idiot with moments of shear and absolute brilliance.
97 TJ with an 01 engine, 92 tranny, and a 91 transfer case. Yeah...its a mutt.
http://www.jeepforum.com/forum/showthread.php?t=711381
Originally Posted by firefighter1c57 View Post
You shouldn't let your mind wonder. It's small, immature, and shouldn't be out on it's own.
chem57guru is offline   Reply With Quote
Unread 03-18-2009, 11:51 PM   #2
RoscoeJ
Originally Posted by chem57guru View Post
Hi all,
Paul
Try turning the key to accesery point and you should see a little hole ,inside the keyhole . Put a paperclip(not a cheap crapz one) or something stronger of similiar size into hole it should pop out ,ithe little hole may even be located in the off position.hope this helps..
RoscoeJ is offline   Reply With Quote
