New speedo gear = AWFUL gas mileage... Why?
| Truck-Lite's New LED Headlamp Series | NEW! Poison Spyder RockBrawler BFH Bumpers! | Poison Spyder BFH Rear Bumpers |
#1 | |
I am running 32x11.5's with 3.73's, 4.0l auto. The speedo gear chart said I needed a 32 tooth gear. I ordered it, put it in my jeep. Everything works great. I reset my computer after changing the gear as well. The only problem is that based on the mileage my odom says and my fuel consumption, I'm getting about 4 miles to the gallon. What is wrong here? Did I use the wrong gear? Has anyone else had this problem?
Blue Jeep Club Member #151 Arizona Jeep Club Founder |
#2 |
Did you check your speed against a gps to see if your speedo is accurate?
If I can get there I can wheel it! CentralMass4wd.com 1993 Ranger 2wd - dd 1999 wranger 2.5 - it gets used for something 1978 international scout - being built 1998 Cherokee sport 4.0 auto 1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/f8/restoring-57-cj5-stock-build-thread-553649/#post5168554 Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900 my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/ |
#3 | |
The only thing that i can think of is did you turn the housing to match the numbers to the dot on the transfer case?
Here is a website to show you what i mean http://www.jeepin.com/features/speedogear/
1999 TJ Wrangler, 4 banger 5-spd Soft-top, full doors 31" BFG AT, 3" Lift 1954 CJ3B Willys Hurricane 4, 3-spd with Warn Overdrive, Snow-plow NGJC# 15 Low Output 4 cylinder Jeep Club Member #166 Build Thread Are You An Offroad Junkie Quote:
#4 | |
#5 |
You dont need a GPS to check the accuracy. You can use the mile marker signs on the highway. Obviously the mile marker signs are 1 mile appart, if your odometer reads more than 1 mile inbetween the signs it is wrong and running fast.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75 and much more... Riddler torture test video Oil Filter Study Useful Axle Info Thread |
#6 |
Do it right or not at all
![]() Join Date: Jan 2003
A 32 speedometer gear is correct. Don't bother rotating the speedometer gear housing as if the speedometer is working smoothly, the speedo gear is properly meshed with the pinion gear inside. That's the only purpose of rotating the housing, so the speedo and pinion gears properly mesh.
What might have happened was when you disco'd the battery to reset the computer, you forgot it also resets the trip odometer so you have likely driven a lot further than your trip odometer is now indicating.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#7 | |
#8 |
Bahahahaha
Thats funny. Oh well at least your not getting 4mpg ![]() |
#9 |
also, while going down the highway and zipping by those miles markers, drive 60mph (use creuise control if you have it), and when you pass the first mile marker, note your trip odometer reading and time it with a stop watch.
at a true 60mph, you will go 1 mile in 1 minute.
Doug www.4x4LED.com - LED lights for Jeeps, cars, trucks, trailers, etc.!! Tiedowns for your Jeep trailering needs! Envy4x4.com Suspension parts/kits, CBs and accessories and other Jeep doo-dads, MOLLE bags and packs too! |
#10 |
i'm really curious how you found a 32 speedometer for a tj!!??!!i thought that there were 31 or 33 for the tj and the 32 was only for the yj......
#11 | |
This is the one for the tj: http://www.quadratec.com/products/55200_40.htm
Blue Jeep Club Member #151 Arizona Jeep Club Founder Last edited by NotOfThisWorld; 11-05-2008 at 09:26 AM.. Reason: url did not post |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
