New shocks - JeepForum.com
post #1 of 3 Old 02-23-2015, 08:21 PM Thread Starter
rramostx
New shocks
I have a question. I'm some what if a noob so be easy in me. I have the RC 2.5" lift, 1.25 BL, and a 1" MML. I have tube fenders ( not highline) and am running 35's. I am in need of new shocks bad. What length shocks should I buy? Should I stick with a shock made for a 2.5" lift? I will be cutting the quarter panels for better tire clearance. So what length shock should I get to get the most flex? If I got with a shock for a 4" lift, how many inches of bump stop am I going to need for the front and rear. Thanks
rramostx is offline
post #2 of 3 Old 02-24-2015, 12:09 AM
LeeMasterGT
You'll need to take measurements to figure out what shocks will work best for you. Also try to determine what up travel and down travel you want. To make it as simple as possible, measure your shock right now at ride height. Then go look up your desired shock and pick the one that will be in the middle of the shock travel (roughly half way between extended and collapsed lengths) that matches your current shock length at ride height.
From there, it's really a matter of how much work you want to do to make improvements. It's possible your current shocks are limiting your travel unnecessarily. Or it's possible that there are other suspension components that are limiting your articulation, so buying shocks and doing work to use more travel would be a waste without replacing those other components. There's a lot of research you can do if you're looking to change things up to make room for more suspension travel. It won't be as easy as picking 4" lift shocks or 2" lift shocks. Also, you won't know exact bump stop numbers until you're all put together. We'll help where we can.
Build
LeeMasterGT is offline
post #3 of 3 Old 02-24-2015, 01:42 AM
Kolak
Vendor
Kolak's Avatar
You'd want something for 2.5" to 3" lift. A shock that's about 24" extended up front and 22.5" or so in the rear will be correct. But take some measurements as suggested above to be absolutely certain.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
