New seal for output shaft on 231? - JeepForum.com
post #1 of 5 Old 11-30-2006, 02:55 PM Thread Starter
blacktjsport
I got a smokin deal on a Currie SYE that utilizes a new output shaft and the stock tailhousing on the transfer case. The only problem is that I will need a new seal for the output shaft on the stock tail cone as well as new lock rings that hold the gears on the shaft. Where is the best place to get these and does anyone have part numbers for these?? thanks in advance and by the way this SYE is the flange style, just like the hack and tap except the shaft was already cut and tapped by Currie.
--Matt
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline
post #2 of 5 Old 11-30-2006, 03:06 PM
jedeason
just go yo any parts store for output shaft seal.
jedeason is offline
post #3 of 5 Old 11-30-2006, 03:33 PM
Dogman
Dogman's Avatar
They sell seals on their site. Not sure why it would be a "special" seal.
http://www.currieenterprises.com/ces...t.aspx?id=2157
John 3:17
Dogman is offline
post #4 of 5 Old 11-30-2006, 04:14 PM Thread Starter
blacktjsport
Thanks for the link. I looked on their site and didn't see it on their site. Good to know they sell them, I will pick one up when I get ready to install it. What about the lock rings, does NAPA or advance sell them or can I reuse the ones already on my stock output shaft??
--Matt
post #5 of 5 Old 11-30-2006, 04:37 PM
James04TJ
James04TJ's Avatar
Just pick up a snap ring assortment.
Call Currie and they can tell you the size seal and snap ring that you need.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
New AA SYE--Now output shaft seal leaking moparjunkee TJ Wrangler Technical Forum 6 07-05-2011 09:46 PM
how do i replace output shaft seal? yjman92 YJ Wrangler Technical Forum 1 09-21-2009 07:56 AM
Replacing t-case rear output shaft seal did I get the right one??? Goobersbro YJ Wrangler Technical Forum 10 06-11-2009 09:19 AM
Rear output shaft seal peebut YJ Wrangler Technical Forum 4 09-13-2005 10:38 PM
Output shaft oil seal Slim YJ Wrangler Technical Forum 5 03-26-2003 01:38 PM
