New Rubicon suspension for 97 TJ 2.5 - JeepForum.com
post #1 of 21 Old 05-26-2013, 01:09 PM Thread Starter
jryanbass
I just got an entire Rubicon suspension, minus the shocks for FREE! Pitman arms, springs, everything, off an 06 Rubicon. All the bushings are good. I am planning on getting some Monroe shocks for it tomorrow and putting everything on. Are there any tricks or anything I should be aware of before I start? I just got it, its a project for me and my husband (I am the more mechanically inclined one lol, my step-dad was a mechanic with 2 daughters, so being the oldest I was the helper) I am so excited to get a decent suspension under it, the one on it is factory and it is SHOT. Unfortunately it wasn't very well taken care of when we got it. I won't be off-roading much with it, its mainly for me and my boys to have fun in and to be a daily driver to get me back and forth to school.
jryanbass is offline
post #2 of 21 Old 05-26-2013, 01:27 PM
esad_b
Did the same thing on my 97 TJ a couple of years ago. Straight forward swap, I do recommend you spray the rear upper bolts prior to let them soak and break the rust loose.
Chances are they will probably snap on you lol and their no fun to remove.
esad_b is offline
post #3 of 21 Old 07-21-2013, 10:28 PM
nickgsjeep
Gain
I'm about to do the same to my 02 2.5L, scored a nearly new Rubi suspension. Did you guys net any gain in height from this swap? Thanks.
White Jeep Club member #273
Low Output 4 Cylinder Jeep Club member
nickgsjeep is offline
post #4 of 21 Old 07-22-2013, 06:49 AM
esad_b
Hey, I did this about a couple of years ago with Rubi shocks and coils but I also added the spacers.
The rubi coils, depending on their rating and in what condition they are you can see gains of up to 3/4". You would want rated coils of 106AA I believe as those are the stiffest.
The shocks do not give you a height increase but will firm up your ride in a good way. 97 TJ shocks are hydraulic while the rubicon and newer model stuff was all gas charged. I had the shocks on my Jeep but I am selling them know as I ended up going higher and needing longer shocks. If you need shocks let me know mine have like 8000miles on them.
esad_b is offline
post #5 of 21 Old 07-22-2013, 07:41 PM
nickgsjeep
Thanks esad. Mine is an 02 but the springs are sagging and the rubi springs and shocks are off of an 06 and they never saw dirt and had less than 20k on them, Ill report my findings when I put them on.
post #6 of 21 Old 07-25-2013, 08:30 PM
esad_b
Sounds good! Spray the rear upper bolts a few days before because they usually snap and are a ***** to remove afterwards due to limiting space.
Sent from the I-device using an APP
esad_b is offline
post #7 of 21 Old 07-25-2013, 11:36 PM
MetalMountainGoat
Hmmm...I was under the impression that the rubi suspension wasn't any different than the regular TJ suspension. I always thought the axles and t case were the only difference.
MetalMountainGoat is offline
post #8 of 21 Old 07-26-2013, 12:52 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
It is the same.
There are different rate coils used on TJs. 4 cyl models come with a lighter rate, I6 models (particularly Rubis) come with slightly stiffer rate coils.
Put stiffer, newer coils on the 4 cyl TJ and it gives a little ride height increase.
Wheelin98TJ is offline
post #9 of 21 Old 07-26-2013, 05:48 AM
esad_b
Originally Posted by Wheelin98TJ
It is the same.
Are the shocks of the early year TJs hydraulic as well while the newer jeeps are all gas charged shocks?
I recall my shocks when I took them off being hydraulic and pretty sure those were OE from the Jeep since 97.
esad_b is offline
post #10 of 21 Old 07-26-2013, 07:30 AM
Tonellin
You won't get any additional height as opposed to when it rolled off the factory floor. You will get a boost back up to the factory height because your 97 springs were probably sagging some. TJ springs are all the same height, but different models/options have higher or lower spring rates. The highest spring rate being an LJ rubicon, auto, with dual tops
Either way it is worth it for you to swap just to get a decade newer suspension into your rig
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #11 of 21 Old 07-26-2013, 08:09 AM
esad_b
Your first paragraph contradicts itself. You are saying he's not going to get any height gain but then you say the coils are a stiffer rate meant for a LJ rubi with dual tops. Hmm I wonder why the factory choose stiffer coil rate for a LJ rubi? To account for the additional weight of all the components.
If the coils are a stiffer rate and he's putting it on a 4cylinder, softtop, d35s jeep instead of a 6cylinder, hard top, d44 of course he's going to see a difference to the fact that everything on the 4cylinder jeep is lighter compared to a rubicon.
Anyways if the suspension stuff is in real good condition and the stuff is going on a 97 jeep with old stuff and its a 4cylinder jeep your prob going to see close to .75" gain.
esad_b is offline
post #12 of 21 Old 07-26-2013, 08:15 AM
rchase559
What do the axles have to do with it?
rchase559 is offline
post #13 of 21 Old 07-26-2013, 08:17 AM
esad_b
They are heavier. Traveling down a road and hitting bumps etc makes them move up and down to which the coils are there to keep them planted on the road I guess?
At first it didn't make sense to me either about the axles but I read that on a thread on JF before
esad_b is offline
post #14 of 21 Old 07-26-2013, 08:23 AM
Tonellin
All TJ springs are the same height regardless of axles, engine, tops, tranny etc. The only difference is the spring rate. He will only see a gain in height because his springs have sagged over 15+ years of driving.
There are a million threads about this on any jeep site...there is no height gain (above factory), but if he got them for free and his old suspension is hurting then a simple swap would benefit him
06 LJ Rubicon
Tonellin is offline
post #15 of 21 Old 07-26-2013, 08:26 AM
rchase559
I think I misinterpreted your post. I thought you were making a correlation between the axle used and static ride height. It sounds like it was more of axle and the selected spring rate from the factory. My bad.
