New Rubicon owner - couple of Q's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > New Rubicon owner - couple of Q's
Unread 11-29-2011, 04:38 PM   #1
mhopton
Hey guys, I have a couple of questions:
1) Does my 06 Rubicon LJ have OEM sway bar disconnects? If so, where? Or, do I need to add the clevis pin, etc?
2) ABS. How do I know if I have ABS? I've looked for an ABS light on startup, but don't see one. I don't know enough about the brake system under the hood to tell if I have it and I'm too lazy to take a wheel off to look for a sensor.
3) My LJ has a set of small spring spacers above the springs with long bump stops, I assume, sticking down inside the spring from the stop itself. Any positives/negatives to this setup?
Thanks,
Mike (happy and proud new Rubi owner)
mhopton is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 04:44 PM   #2
Jason
#1 - No. Electric disconnect started with the JKs
#2 - Slam on your brakes on a loose surface. Or look for a gizmo under the hood on the driver side behind the wheel well. If there is an empty plate (looks like a battery tray), no ABS. If there's a gizmo, ABS. There should be a light on the dash when you fire it up as well.
#3 - Not really. Little more clearance with a factory ride.
Jason is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 04:45 PM   #3
freeskier93
1. No.
2. Drivers side fender, under the brake master cylinder. If the tray is empty you don't have ABS, if there is a pump looking thing and brake lines you have ABS. Or smash the brake pedal, if the tires lock up you don't have ABS.
3. Sounds like the factory spring isolators.
CU Boulder Aerospace Engineering
freeskier93 is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 04:52 PM   #4
mhopton
Gotcha, thanks guys. Anyone know the link to the jeep site that allows you to input your VIN and request an original build sheet with the exact factory equipment?
Mike
Unread 11-29-2011, 04:55 PM   #5
l0p3z187
Mike
I got my build sheet using the following link. It took about 1 day.
http://www.jeep.com/wccsapp/universal/J/index.jsp
The link may not work. Go to www.jeep.com, on the bottom of the page, click on the "Contact Us" link. Then the "Customer Assistance" link. From there, click on the "Send us an Email"
Good luck! And hope you enjoy your Jeep!
l0p3z187 is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 04:56 PM   #6
WahooTJ
I'm about 99.9% sure that ABS was not available on TJ Rubicons (not sure about JKs)
WahooTJ is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 11:43 PM   #7
joe108
No abs was available on 03 to 06 rubis
joe108 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2011, 12:53 PM   #8
mhopton
Yep, no ABS. Picked up a build sheet from the dealer to confirm. Thks
