New rough country n2.0 shocks - Page 18 - JeepForum.com
post #256 of 304 Old 12-09-2011, 12:48 PM
aparke4
yeah RC has had a bad rep for some time but I really have been pleased with all my parts and purchases... they are turning things around with service and quality of parts... i really am surprised my TJ is riding on their coils and soon - hopefully tonight- their shocks! and i like them! ok nuff' talk - shock pics!
aparke4 is offline
post #257 of 304 Old 12-09-2011, 12:59 PM
aparke4
measured lengths:
front n2.0, part number: 20008
compressed: 15 to 15.5 inches (not fully compressed - maybe 1/4 to 1/2 chrome showing - hence the 15 to 15.5 mark)
extended: 26 inches
this is measured to where the ring on stud is that sandwiches the bushing between the ring and shock stud
rear n2.0, part number: 20009
compressed: 14
extended: 24
measured bar pin to bar pin
aparke4 is offline
post #258 of 304 Old 12-09-2011, 01:03 PM
aparke4
they also look and feel like rancho shocks...
aparke4 is offline
post #259 of 304 Old 12-09-2011, 02:55 PM
2003X
Hurry up and install them.
My Build
2003X is offline
post #260 of 304 Old 12-09-2011, 04:46 PM
aparke4
ok just installed em! taking the jeep for a ride... pics in a bit...
aparke4 is offline
post #261 of 304 Old 12-09-2011, 05:00 PM
jutgin
I installed mine a few days ago. I would say a little better than the 2.2's but nothing to get too excited about.
Justin
2013 Wrangler Sport
Chattanooga, TN
jutgin is offline
post #262 of 304 Old 12-09-2011, 10:52 PM
aparke4
just drove around the block and over some speed bumps... nothing too exciting...
definitely firmer than the hydro shocks i had on there... seems to have a little less sway in the corners (to be expected with a nitro shock)... going over speed bumps at 30 mph was more comfortable - the back end did not "drop" like the hydro shocks did... not as caddy as old man emu springs/ shocks but for RC coils (I have 2.5 progressive 4 cyl rate - 7 months on em with body armor, winch, spare 33, bumpers) and shocks the road manners are great.
anyways needs more miles and such but I am a happy camper - installed pics in the morn!
aparke4 is offline
post #263 of 304 Old 12-10-2011, 07:26 PM
aparke4
jeep overall:
aparke4 is offline
post #264 of 304 Old 12-12-2011, 07:54 PM
2003X
Let us know after you have broken them in how they ride.
My Build
2003X is offline
post #265 of 304 Old 03-11-2012, 07:35 AM
rusty577
Ive got a new set of these N2.0 shocks in my XJ Jeep. Unfortunately I slid back into a rock today while wheeling and have put a big ding/crushed the bottom of the shock tube.
Doesn't look like its been punctured or leaking but will I have to replace it?
rusty577 is offline
post #266 of 304 Old 03-11-2012, 07:53 AM
Muddeprived
Muddeprived's Avatar
These are still not listed on their website for purchase? What's taking so long?
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #267 of 304 Old 03-11-2012, 12:03 PM
2003X
Good question.
My Build
2003X is offline
post #268 of 304 Old 03-11-2012, 01:34 PM
crateampscal
i have them but my opinion is irrelevant. i have them, but the rear end of my jeep rides like complete crap since i did the sye and angled the pinion. if i relocate the rear spring it would probably be a lot better.
crateampscal is offline
post #269 of 304 Old 03-13-2012, 10:18 AM Thread Starter
B2CARPEN
I have some updates related to the performance of these shocks.
About after 6 months from first installing these, I noticed that both front shocks lost pressure and leaked. The rear shocks were fine and still were pressurized. When I removed the fronts, both piston rods no longer extended. Keep in mind that this was only from daily driving, these shocks had yet to see offroad use. I called Jeffery and he sent me two new front shocks immediately, always the best service. I installed the new front shocks just in time to test them off road at the Badlands IN.
As for handling, these shocks are great for daily driving and very light offroad use, but I do not recommend them for moderate to extreme off roading. I noticed the shocks beginning to gas out and lose pressure very quickly when our group left the parking lot and ran through the dunes over to the quarry. The dunes was high speed with lot of woops and bumps which really put the shocks to the test, but by the time I got to the quarry the shocks had lost their stiffness and felt extremely soft. Stabilization became less as I climbed up rock walls and over rock sections. These shocks definitely made the ride smooth, but it got scary at times when the weight of the jeep would shift and rock back and forth, or bounce.
Keep in mind, I am on LAs with no sway bars so I have very little CA resistance and naturally more side to side roll. My setup greatly relies on coil / shock performance and I can easily tell when the shocks begin to fatigue because it causes major instability. I'm going to switch to a stronger high performance shock / coil setup down the road.
So far I haven't noticed any leaking from the new set of front shocks, and the rears are fine as well so it might have been a random fluke, but keep an eye for leaking around the seal where the piston rod slides into the shock body.
Founder of
B2CARPEN is offline
post #270 of 304 Old 03-13-2012, 10:22 AM Thread Starter
B2CARPEN
It would definitely make the ride a lot better. I have rear coil relocators and they make the world of difference. Not to mention, having too much of a bend in your coils for too long of a time can eventually wear them out and cause coil fatigue.
Founder of
B2CARPEN is offline
rough country shocks ram07k TJ Wrangler Technical Forum 8 09-03-2010 07:58 AM
Rough Country Shocks ? Dog Man TJ Wrangler Technical Forum 11 12-29-2009 02:45 AM
Oil in Rough Country 2.2 shocks? Ajl9791 TJ Wrangler Technical Forum 5 09-26-2009 07:59 PM
Rough Country 2.2 shocks cowboy1107 TJ Wrangler Technical Forum 9 09-06-2009 10:25 AM
Rough Country Shocks SuMeRiaN TJ Wrangler Technical Forum 5 08-07-2005 07:50 PM
