New Rockers from PSC..... - JeepForum.com
Closed Thread
post #1 of 206 Old 01-09-2006, 10:18 PM Thread Starter
Difranco
Difranco's Avatar
I like the styling, it really stands out as something unique. What do ya'll think of the "Helldorados"?
Orange Jeep Club Member #13--Metalhead Jeep Club Member #13--Poseur Jeep Club Member #13
Gun Control: Means never having to say "I missed you!"
FOR SALE: OE Rubicon Shocks / OE Rear Bumper / OE 3rd Brake light / OE Front Trackbar / OE Rear Trackbar -- PM for details and make your best offer.
Difranco is offline
post #2 of 206 Old 01-09-2006, 10:28 PM
Texas TJ
Texas TJ's Avatar
i like em but there probably gonna cost like 600 bucks
2001 TJ YELLOW
I flopped and broke my piece
If it won't budge, get a bigger hammer, if it breaks in the process it needed to be fixed anyway.
Texas TJ is offline
post #3 of 206 Old 01-09-2006, 10:30 PM
biffstephens
biffstephens's Avatar
I doubt that.....everything PSC has is prett resonable for what you get.....
Wheel Spacers? Aluminum Fairleads? Winch Rope? LEDS? Winches? Accessories.....
Biff
biffstephens is offline
post #4 of 206 Old 01-09-2006, 10:32 PM
Kerndone
I lack money
Kerndone's Avatar
They don't appear to extend very far underneath. The design looks cool, but it also looks like it can be done to just about any rocker that has a step/slider.
-Frank
Red Jeep Club Member 111
'99 TJ - work in progress...see profile
'08 WK - Silver RME, DD.
Kerndone is offline
post #5 of 206 Old 01-09-2006, 10:35 PM
UCTJ
UCTJ's Avatar
They are coming out with all kinds of new stuff...there a new trail cage called Hellorado as well.....
UCTJ is offline
post #6 of 206 Old 01-09-2006, 10:58 PM
1000000to1
1000000to1's Avatar
Look cool might have to upgrade my psc's
If it doesn't have a motor I don't want to play with it!
Canadian Jeep Club Member #18
Black Jeep Club Member #2002
1000000to1 is offline
post #7 of 206 Old 01-10-2006, 12:02 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I've played with the PSC a bit more since my last post about their design flaws and have since discovered that my original theories are now bearing fruit.
Someone at PSC needs to learn a few things about rockers.
This whole sandwiching between the body mount and tub is a crap design. Those three mounts under the doors sit in dimples on the underside of the tub. Those three mounts are designed to be compressed a specific amount to carry the weight of the tub. How do you expect that to happen if you compress 2 of them a half inch more than the one in the front because you span over the dimple instead of up into it?
Would anyone here in their right mind shave a half inch off of two body lift pucks on each side under the doors and call that correct?
How about if I send the guys with no body lift 4 half inch thick pucks and have them install them under the doors on the last 2 mounts on each side? Would that be okay?
Further, look at the rear slot on the rail. See that little finger of metal pointing to the inside? Guess what happens to it when the over compression of that body mount gets done with it?
There is ample room to make that finger another inch wider so that it won't distort up into the dimple in the body.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #8 of 206 Old 01-10-2006, 12:05 AM
Texas TJ
Texas TJ's Avatar
sweet jesus man...
if you don't like the design DONT BY THEM!!!!!!!!
dont cry about them on the internet
2001 TJ YELLOW
Texas TJ is offline
post #9 of 206 Old 01-10-2006, 08:52 AM Thread Starter
Difranco
Difranco's Avatar
Last I read about PSC rockers you were supposed to trim about 1/4" off those pucks.
Difranco is offline
post #10 of 206 Old 01-10-2006, 09:38 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
What do you do if you don't have a body lift?
I am Savvy
post #11 of 206 Old 01-10-2006, 09:39 AM
redrock4x4
redrock4x4's Avatar
While I haven't installed a set or really looked at the mounting system up close I think I understand what you're saying.
So if they were going to use this style of mounting system properly, the way to do it would be to insert the rocker guard in between the frame mount and the top body mount so that the top body mount still sandwiched in the concave in the body, correct? So the order would be body > body mount > rocker guard > body lift (if used) > frame. This would work better assuming you have a flat body lift puck and not a contoured one like Currie makes.
The only potential problem I could see here is that this may create a gap between the rocker guard and the body...
I suppose another potential fix would be to include a new shorter body mount which goes under the rocker guard and fills in the concave in the body properly. If you chop 1/2" off your body lift puck and insert it in between the rocker guard and the body does that fill in the concave properly? The best solution would be to provide a new shorter body mount here that installs above the rocker guard yet does not create a gap between the rocker guard and the body.
Looking through their website it appears they have changed their mounting system to what I described above for the Unlimited:
vs. this for a standard TJ
redrock4x4 is offline
post #12 of 206 Old 01-10-2006, 09:56 AM
The Mean Fish
The Mean Fish's Avatar
You don't buy those rockers.
PSC sells cage kits for YJs but I don't have a YJ, whatever will I do???
The Mean Fish is offline
post #13 of 206 Old 01-10-2006, 10:00 AM
redrock4x4
redrock4x4's Avatar
Is the body mount strong enough that you could cut it in half (rough guess) and still re-use the upper portion above the rocker guard??
post #14 of 206 Old 01-10-2006, 10:03 AM
redrock4x4
redrock4x4's Avatar
I think that for someone who wants a useful side step that's the best design I've seen
post #15 of 206 Old 01-10-2006, 10:08 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Texas TJ
sweet jesus man...
How would you like to buy a set thinking that they were pretty good for playing in the rocks only to have them let the rocker slide inwards because it's only clamped in place with the body mounts? That caves in the rocker right where the spider logo is.
On the rig I was working on, it caved in the rocker enough to slightly crumple the floor.
Is that what you want your rockers to do?
I am Savvy
Closed Thread
Which rockers from q tec? $lick TJ Wrangler Technical Forum 15 08-03-2007 09:04 PM
Anyone use these rockers? mferrari TJ Wrangler Technical Forum 2 05-18-2006 06:31 AM
New rockers are on :-) Chris_L TJ Wrangler Technical Forum 3 03-04-2005 10:05 AM
Aev Rockers chris06 TJ Wrangler Technical Forum 23 01-16-2005 08:33 PM
AEV Rockers Builder15 TJ Wrangler Technical Forum 1 08-21-2004 08:43 AM
