New Radiator - Silla All Aluminum
| Truck-Lite's New LED Headlamp Series | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! | Poison Spyder DeFenders™ - "Tubeless" Jeep Fende |
#16 | ||
2000 TJ, 4.0l, 5 speed NV3550, Interco Trxus 35x12.50, Skyjacker Long Arm 4" lift |
#17 |
Updates..
Anyone else have feedback about this Silla Alum Radiator? I'm thinking of buying one....my OE one is leaking
![]() Thanks in advance,
97 TJ, 88 M3, 95 M3, 96 328I Track Car, 00 F150 and a 04 HD Road King Custom (Buy me!!) - Thinning the herd to focus...heheh |
#18 |
I bought my single core Silla aluminum radiator from radiatorexpress.com for under $200 shipped!
Gotten Savvy! Awaiting Tummy Tuck ;-) http://video.google.com:80/videoplay?docid=-2512249746173560379&pr=goog-sl 65 million firearms owners killed no one yesterday - Assault is a behavior, not a device. |
#19 |
roadking - how did you mate up the trans lines to your auto? My lines seem to terminate directly into the OE radiator..not a hose with clamp as the nipple on the provided connections. Thanks in advance.
#20 |
Scanguage II will read temps accurately no problem. I've got one. Those TIG welds aren't the prettiest, but it looks like a good radiator. Let us know how it holds up.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#21 |
I have had my silla all aluminum radiator in for about 2 months and it has been keeping the 4.0 about 5* cooler than the stock one. (I am running a 195* t-stat).
I got mine from http://www.fastradiator.com/ViewProduct.asp?ModelNumber=FAS-2102AA $135 out the door...then again I picked it up in person since they are only an hour from my house but they will ship it for $7 I think.
2002 Sahara 4.0L/NV3550/NP231/D30/D44 35x12.50x15 MTRs RC 2.5" Lift & 1"BL 1998 Dodge Ram 2500 4x4 CTD |
#22 |
Mine has worked great for about 5 months.
#23 |
I can't remember if I just unbolted them from the OEM or used the new ones that came with the radiator? I think I cut the lines and used the new ones? Just keep the lines elevated so they don't drip all over the place.
#24 |
Silla Install for Automatic Tranny
Thanks for all the input/write-up everyone....I bought a Silla Alum 1-Core Radiator and here's the scoop for my 97 TJ Automatic 4.0 Install
The hard lines from the Auto Trans will leak a very small amount of fluid - not much to replace/add back to the trans. The capacity of ATF in the Rad is very little as well - not much worries for amount that drains. Best of luck - 2 days in the TJ and (fingers crossed) - continued success.
#25 |
Just bought one of these, weather permitting going to swap it tomorrow. How much water and antifreeze is this going to take. And should I get a 18 pound cap like the one that's on it or something else?
#26 |
MAIL Crawler.
heres a weird question for you guys that swapped in these radiators: are the mounting brackets on the sides welded on, or bolted on like a stock rad? also, is this the part number that everyone is using...FAS-2102-2AA? tia
edit: this thread was old. dangit. ![]()
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1. *85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces. NEW and USED parts for sale. PM me. |
#27 |
Yes, the mounting brackets are on there already and it just bolts right up. It also has the receptacles for transmission cooler lines if you have an auto trans. Not sure about the part numbers, it was a while ago that I bought it.
#28 | |
MAIL Crawler.
heres why i ask: whoever converted my TJ made the rad brackets removable so that i can replace it with an OEM style rad for a LHD TJ. and yes i have tried to fit a RHD model rad in there. it wont work. i am looking for a rad that i can remove the mounting brackets and put my goofy ones on there to fit my TJ. do you copy? not trying to sound like a d!ck, but it is so frustrating to have to compensate for the p!ss poor quality of conversion that is my Jeep. ![]()
#29 | |
#30 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
