Quantcast new pics and install tips - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > new pics and install tips
Old 12-18-2003, 09:07 PM   #1
wilg5490
04 rubicon 35"tires 4.5 extreme lift
http://www.imagestation.com/album/?id=4288301303&idx=10
when you get to imagestation please hit the PREVIOUS button to see all pics
http://www.imagestation.com/picture...14/fa45777c.jpg
http://www.imagestation.com/picture...30/fa45777b.jpg
http://www.imagestation.com/picture...33/fa457767.jpg
Here are some great install tips for the 4.5 rubicon lift
Manufacturing Air Compressor Relocation Bracket
Before removing the pan you will see an anodized bracket at the rear left side of the pan holding 2 air compressors. Unbolt the bracket and remove the pan remove all electrical connections from the bracket and the compressors. Unbolt the compressors and let them hang by the air lines. Now take the long end of the bracket and bend it straight up, you will need a vice and a hammer. This bracket is very hard to bend. Once you have it like the picture below you can remount the compressors just the same way they came off and hook all electrical connectors back. Now you are ready to mount the plate back up. I used two ¾“ self tapping screws on the side and one 2” self tapper on the left side with a 1.25” spacer. You can also use some nuts and bolts, the screws did come up just a little under the seat. The compressors will be close to the underside but shouldn’t touch, now zip tie your wires and your done.
http://www.imagestation.com/picture...94/fa457745.jpg
wilg5490 is offline   Reply With Quote
Old 12-18-2003, 09:11 PM   #2
Bucket110
none of the pictures are working.
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear
2003 F350 diesel....tow rig
[COLOR=blue]NEJEEPZ[/COLOR]
[URL=http://community.webshots.com/user/2k2blktj]My Jeep[/URL]
Bucket110 is offline   Reply With Quote
Old 12-18-2003, 09:13 PM   #3
carlson
carlson's Avatar
Your links don't work.....
2012 Black Rubicon Unlimited
--<\O ||||||| O/>--
'''''''_\o<###>o/_'''''''
carlson is offline   Reply With Quote
Glock Forum
