new motor mounts? swap 2.4 to 4.0 - JeepForum.com
post #1 of 11 Old 07-25-2010, 11:55 AM Thread Starter
ACL
I get that I need to change the mounts in swapping the 4.0 into my 97 2.5 TJ but do they require welding? Where can I buy them?
ACL is offline
post #2 of 11 Old 07-25-2010, 01:57 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Welcome to the forum!Yes it will be a weld in job.You could contact here. AdvanceAdapters.com | Engine & Transmission Conversion Adapters - Advance Adapters
GOLENJEEPTJ is offline
post #3 of 11 Old 07-25-2010, 02:36 PM Thread Starter
ACL
Thanks for the tip & the welcome. I went to Advanced adaptors and looked around some and didn't find the mounts. I guess I'll have to look harder. I also noted on another thread a post w/ mount part #'s but I wasn't clear where the mounts came from in that post.
I have some other questions such as will the bell housing from the 94 4.0 Cherokee meet up w/ my 97 2.5 TJ trans? Or should I try to put the Cherokee transmission and transfer case in there and if so what about the driveshafts?
ACL is offline
post #4 of 11 Old 07-25-2010, 02:40 PM
GOLENJEEPTJ
Here would be a good place for you to start.The AW4 trans would be a good swap because of the overdrive! http://www.stu-offroad.com/engine.asp
post #5 of 11 Old 07-25-2010, 02:42 PM
GOLENJEEPTJ
Stu's a great guy and does alot for this forum! Lot's of info on his site.Shoot him a PM!
post #6 of 11 Old 07-25-2010, 04:16 PM Thread Starter
ACL
Thanks, I will. I've been looking further into the matter and it seems that I should pull the TJ 2.5 transmission & transfer case out as well and put in the AX-15 w/ transfer case that came w/ the 94-96 Cherokee. Better transmission I understand. Still concerned about the driveshafts though.
Found the motor mounts at Browndogs but wish there was a bolt on arrangement as I don't have a welder and hate to haul it to weld the mounts.
A little concerned about the change in transmission length and transfer case too.
With the mechanical portion out of the way I still have to deal w/ the accessories - AC radiator and so on and then the electrical.
One thing at a time...
ACL is offline
post #7 of 11 Old 07-25-2010, 04:21 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The transmission behind your 2.5 will not bolt up to a 4.0 I6, so a tranny swap will be required rather than optional.
You could have a welder come to you to do the motor mounts.
Wheelin98TJ is offline
post #8 of 11 Old 07-25-2010, 04:32 PM Thread Starter
ACL
Thanks for the reply. Yea, at first I thought it would be easyer to change the bellhousing at the trans if possible and mate it up but I guess not. Thats ok though cuz if the AX-15 is a better piece I have it and might as well use it. When I stripped the Cherokee I thought it might come in handy even if only to sell it to recoup costs.
What about the drive shafts? Isn't the lengths w/ the new arrangement gonna be different?
ACL is offline
post #9 of 11 Old 07-25-2010, 04:42 PM
Wheelin98TJ
JEEP FREAK
The required driveshaft lengths after the swap will end up being real close to what they were previously.
I would not try to plan the motor location around the driveshaft lengths.
post #10 of 11 Old 07-25-2010, 05:13 PM Thread Starter
ACL
Ok thats great. Thanks again. I guess I'll know whether to use the Cherokee's shafts or the TJ's shafts when I get there.
And bringing Mohomed to the mountain, the welder to the jeep, makes good sense too provided I can find the welder. I do know of a couple of shops around here.
What about removing the front clip to do this work does that make sense to you?
ACL is offline
post #11 of 11 Old 07-25-2010, 09:20 PM
Wheelin98TJ
JEEP FREAK
Yes, I would pull the fenders and grill.
It does not take too long.
engine swap , motor mount
4.3L engine swap motor mounts. Pics requested mcgann454 TJ Wrangler Technical Forum 7 01-16-2009 06:38 PM
Trans-Dapt motor swap mounts cooltc2004 YJ Wrangler Technical Forum 9 12-22-2008 07:53 AM
Weld-in motor mounts for V8 swap dragginwagon406 YJ Wrangler Technical Forum 3 06-13-2008 05:39 PM
Motor mounts Pathogen1337 TJ Wrangler Technical Forum 6 04-21-2008 05:39 PM
4.0/350 swap motor mounts???? kyle01041981 YJ Wrangler Technical Forum 1 04-24-2006 02:20 PM
