New Moog track bar, but steering wheel is off center. - JeepForum.com
post #1 of 18 Old 05-02-2015, 11:07 AM Thread Starter
banjo_picker
I just put in a new Moog DS1235 track bar in my '99 TJ. My wobble issue is taken care of, but now my steering wheel is off center. The track bar seemed slightly longer than the stock one.
I test drove the Jeep for a few miles and it is driving fine and tracks straight when I take my hands off the wheel. The only issue is that the wheel is off center.
Is this normal/expected? And what should I do about it? Get an alignment? Am I going to screw up anything if I drive it?
Thanks!
banjo_picker is offline
post #2 of 18 Old 05-02-2015, 11:34 AM
pismo61
pismo61's Avatar
2015 JK Wrangler
I think they maybe longer.Im up 2.5 inches and centered with the Moog track bar.I read on this forum somewhere on this forum they were longer,like a 1/4 inch a few days ago.Just center your steering wheel,then you should be good.
2015 Red 2 Door(half) 6sp.
pismo61 is offline
post #3 of 18 Old 05-02-2015, 11:35 AM
98TJSE
Another Moog issue LOL
you can leave it but remeber on full lock your extending the clockspring further then before(direction it is already turned a bit)
You can also recenter your steering wheel by adjusting drag link, loosen both bolts on the sleeve clamp and a pipewrench work wonders.. this is just to recenter steering, this has no effect on actual alignment .. heres a pic..
http://project-jk.com/gallery2/main....2_itemId=49527
98TJSE is offline
post #4 of 18 Old 05-02-2015, 12:14 PM
jeepn4life92
You won't screw anything up by driving it, but I'd adjust it the way 98tjse mentioned. Don't waste your money on an alignment, it's nothing you can't do yourself.
jeepn4life92 is offline
post #5 of 18 Old 05-02-2015, 12:59 PM Thread Starter
banjo_picker
Cool. So I loosen the two nuts in the picture, and then turn the turnbuckle as needed?
Thanks!
post #6 of 18 Old 05-02-2015, 02:12 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Thanks!
You got it.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #7 of 18 Old 05-02-2015, 03:56 PM Thread Starter
banjo_picker
Got 'er done. Thanks guys!
post #8 of 18 Old 05-02-2015, 04:19 PM
Leffnasty
Quick question that's relevant. I centered the wheel after a new track bar, but when the wheel is centered the pitman arm is definitely NOT straight, actually quite far to one side. I have driven it couple hundred miles and wheeled once with no issues. This wouldn't cause any problems with the steering box would it?
Leffnasty is offline
post #9 of 18 Old 05-02-2015, 07:32 PM
TimV
The pitman arm is not mounted straight out on a TJ. If you have the same number of turns of the wheel to go full left as full right, you got it right.
It's not an addiction. It's a way of life.
TimV is offline
post #10 of 18 Old 05-02-2015, 07:52 PM
26679cj5
Don't use a pipe wrench anywhere on your steering linkage. It can create stress risers. Lube the turnbuckle with antisieze before assembly, and it will never need anything more than a turn of the wrist to adjust once you have loosened the bolts.
26679cj5 is offline
post #11 of 18 Old 05-02-2015, 08:14 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
For some OEM parts that never had antisease applied to the to the threads, using a pipe wrench is inevitable...
Knuckelhead is offline
post #12 of 18 Old 05-02-2015, 08:20 PM
26679cj5
On the drag link or tie rod adjusters? No way. There is a hook shaped tool made specifically for adjusting them, or spray a little lube in there and use a flat head screwdriver or similar in the open gap to work it loose.
26679cj5 is offline
post #13 of 18 Old 05-02-2015, 08:46 PM
98TJSE
ive used pipe wrenches for 20 years never once did I have an issue just gotta be smart, and use common sence like using a hi lift LOL ..
98TJSE is offline
post #14 of 18 Old 05-02-2015, 09:07 PM
26679cj5
I carry one in my tool bag too,but it's a last resort type of thing...lol.
26679cj5 is offline
post #15 of 18 Old 05-03-2015, 08:15 AM Thread Starter
banjo_picker
FWIW… I soaked mine in PB blaster and it turned easy by hand.
