New Mobile One 0W-30 and 2005 TJ Jeep - JeepForum.com
post #1 of 17 Old 04-10-2009, 10:34 PM Thread Starter
Archon2561
Has anybody used the New Mobile One 0W-30 oil in a 2005 6 cyl TJ and how well does it work I am planning the next oil change to change to this oil
Joe
Archon2561 is offline
post #2 of 17 Old 04-10-2009, 11:09 PM
jeep2029
I have a 2006 Jeep Wrangler X 6 cyl 4.0L, and Mobil 1 10W-30 was recommended by JF, the manual and...http://jeep.us41.org/.
5W-30 oil can be used. 5W-30 is more fluid at cooler temperatures, but in the heat it breaks down faster. So, 5W-30 might be useful for someone in Montana during the Winter to prevent extra engine wear and assist with cold weather starts, but for the most part, 10W-30 is the oil for your engine.
May be different depending on the average temperature where you live or driving conditions/habits (towing etc.)
jeep2029 is offline
post #3 of 17 Old 04-11-2009, 03:49 PM
sealion2288
0W-30 is for Hybrid engines.
sealion2288 is offline
post #4 of 17 Old 04-11-2009, 03:53 PM
JBTJ
What? It is for any engine. More so for colder climates.
JBTJ is offline
post #5 of 17 Old 04-11-2009, 03:57 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
GOLENJEEPTJ is offline
post #6 of 17 Old 04-12-2009, 09:02 AM
Zeep
I ran it this past winter, no difference in fuel economy, lifter noise, or performance what so ever!
switched back to 10w-30 last oil change, intend to stay there.
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
post #7 of 17 Old 04-12-2009, 11:16 AM
AKTJ
Amsoil
PM Ridin' Around and I am sure he can provide you with a better alternative.
AKTJ is offline
post #8 of 17 Old 04-12-2009, 11:34 AM
Pillswoj
I would doubt that the M-1 0w30 has the higher levels of Zinc required by the 4.0, the M-1 High Mileage 10W30 does.
Friends don't let Friends run Bosch
Pillswoj is offline
post #9 of 17 Old 11-20-2009, 10:46 PM Thread Starter
Archon2561
I have been using mobile One 0W-30 now for 1 1/2 years I do get better gas mileage usually 1 or 2 miles better I use it all year 1 nice thing the engine heats up faster in winter too.
post #10 of 17 Old 11-20-2009, 11:55 PM
RogueSpear2023
The only thing 0w-30 will do is allow your motor to move more easily when cold in the winter, which if you warm up you vehicle sitting a lot may make the MPG difference, other wise at operation temp is it at 30 so it makes no difference. I run 5w30 in the winter, and 10w30 in the summer. If you live in a warm climate I would run 10w30 year round
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #11 of 17 Old 11-21-2009, 08:52 AM
2000jeeper
WRONG ANSWER HANS!!! It can be used in any engine. Like previously stated more so for colder climates.
On that note i have been using Amsoil 0w30 in my heap since i bought it from my dad with 60000 miles on it.
AMSOIL DEALER
2000jeeper is offline
post #12 of 17 Old 11-21-2009, 09:27 AM
pielet97
Theoretically, the thinner the oil, the better in winter, better MPG due to less viscosity BUT less protection in normal climates. If the protection was exactly the same, they would only sell and recommend the thinnest stuff available.
I require things to do.
pielet97 is offline
post #13 of 17 Old 11-21-2009, 09:51 AM
Ridin' Around
Less protection is not correct. It is still a 30 weight oil at operating temperature. The 1st # is how the oil act when it is cold, or in the WINTER, which is what the "W" represents, ie 10W-30 or 0W-30. Both meet the requirement set forth within the SAE guidelines. Google now!
A 0W-30 has met the requirements of a 5W & a 10w-30. The better flowing 0W can reduce wear at startup, which is wear the majority of engine wear comes from.
The reason that not all companies sell a 0W oil is that it is more expensive to create a product with the broader operating range. OEMs are going lighter on required viscosities as they have discovered it is an easy way to squeek out a MPG improvement. This means that the oil is having to work harder.
Ridin' Around is offline
post #14 of 17 Old 11-21-2009, 10:11 AM
pielet97
If this is true, than why don't the automobile manufacturers (GM) specify 0W?
pielet97 is offline
post #15 of 17 Old 11-21-2009, 11:49 AM
Ridin' Around
Many oems are calling for lighter weight oils, GM suggesting 5W-30 for a while now, Chrysler and Ford have moved to a 5W-20 in most of their new cars and Toyota has a spec out for a 0W-20 in most of their new cars. This includes the 2009 Tundra with the 5.7 V-8. I know this because I just switched my neighbor's new truck over to Amsoil for him. He was having trouble finding a true PAO synthetic 0W-20 and Amsoil was one of the few he could find.
It's coming. The new ILSAC spec is going to specify some fuel mileage requirements and lighter oils are helping meet that.
Main GF-5 Site Performance
use that link and you can see the changes that are in the works.
Mobile 1 How Many Miles 20181c JK Wrangler Technical Forum 21 10-26-2009 05:51 AM
ATF+4 same as Mobile 1 Synthetic ATF? PrinceBondar JK Wrangler Technical Forum 1 08-19-2009 07:37 PM
Replace AMS oil with Mobile 1, storman113 TJ Wrangler Technical Forum 1 02-14-2009 03:25 PM
Mobile gas station for my JK BRICKTOP2 JK Wrangler Technical Forum 13 01-02-2009 01:39 PM
anyone use mobile 1 15,000 mile oil? losfreddy TJ Wrangler Technical Forum 10 04-20-2006 09:02 AM
