-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   New lockers and new Atlas adds a crescendo of new noises. (http://www.jeepforum.com/forum/f9/new-lockers-new-atlas-adds-crescendo-new-noises-2045473/)
M1ark 01-27-2014 10:13 PM
New lockers and new Atlas adds a crescendo of new noises. (Solved)
Just had the following done. The jeep went from a quiet stock jeep with a 4" lift as the only mod to this. Now it sounds like a farm implement. I will eventually get used to the crescendo of new sounds. Can't wait for wheeling this weekend.
TJ Ford 8.8 axle 4" lift ($2495)
- Artec Truss
- 4.56 gears / master install kit
- Yukon Grizzly locker
- Yukon 8.8 c-clip elim kit
- disk brake / e-brake
Labor / Install - Ford 8.8 Includes new brakes / u-joint / conversion ($400)
D30 4.56 gears / master install kit ($250)
Labor / Install($250)
D30 Yukon Grizzly locker - free install ($520)
Yukon Inner and Outer 4340 TJ shaft kit - free install ($550)
D30 unit bearings - free install ($170)
Ballistic Fab D30 / 8.8 HD diff cover ($230)
D30 Front Artec truss w/ Artec C-s ($155)
Labor / Install ($200)
- free gusset Dana 30 lower control arm.
Atlas 2 3.8 ($1400)
Labor / Install - atlas ($500)
New rear custom CV driveshaft ($99)
Shorten front drive shaft and overhaul ($98)
Total $7609
aparke4 01-29-2014 01:28 AM
Pics! Hell of a set up!
A4LiterV8eater 01-30-2014 02:35 PM
The only thing I would think would add noises is the Grizzly Locker unless the drive shafts were setup improperly. What do the noises sound like?
EDIT:
Actually I take that back, depending on your cross member, body lift, trans mount, and the way you have your atlas clocked, the Atlas could be tapping the skid or underside of your body.
MO2500 01-30-2014 06:30 PM
Originally Posted by M1ark (Post 19821169)
Atlas 2 3.8 ($1400)
Unless you meant $2400, was the Atlas used? If not, I need to know where you got a deal like that!
M1ark 02-02-2014 11:42 AM
Used. Original owner going to an Atlas II 4.3 with the 32 spline front output shaft.
M1ark 02-02-2014 11:55 AM
EDIT:
Crescendo getting quieter. Probably due to breaking in. Grizzly locker makes a noise when I clutch and declutch. Not a big deal. Grizzly locker quiet turning corners so this noise would be a lot better with an auto transmission.
I don't have cable shifters for the atlas so I do pick up more transfer case noise in the cabin at freeway speeds or if I'm in the wrong gear at low speeds. This too is getting better primarily due to driving better at low speeds. I realized I had bad driving habits in the past with my stock setup because the chain drive 231 was more forgiving with noise feedback.
My pinion angle with my front axle and drive shaft requires adjusting (I have fixed upper and lower control arms in the front). I am getting adjustable control arms to help fix this and maybe even lock out front hubs to help freeway noise.
Otherwise it is really all working out great. Just a shock going from stock driveline to a capable driveline.
So far very happy with the transformation.
M1ark 02-02-2014 03:25 PM
7 Attachment(s)
Here you go…
Attachment 1054585
Attachment 1054593
Attachment 1054601
Attachment 1054609
Attachment 1054617
Attachment 1054625
Attachment 1054633
Mulvihill64 02-02-2014 11:45 PM
Pinion angle looks to be a little low... Could just be the pic though
M1ark 02-03-2014 12:23 AM
That's the front axle. It is low.
Mulvihill64 02-03-2014 12:26 AM
no, I'm talking about the rear pinion angle
hokahay 02-03-2014 05:07 AM
I had a full Savvy 3" with a one inch BL and the Original UA and GTS along with a new front axle and all new suspension parts. It made all kind of noises. I had a muffler shop make some minor adjustments for 40 bucks to fix a known problem, but after that it settled in and now its back to no noises or funny sounds again. Of course, quiet like a luxury car on a country lane it's not.
M1ark 02-03-2014 07:48 AM
I'll take a better picture and post. I thought the rear was fine.
M1ark 02-03-2014 07:50 AM
It is getting much better. I only have marble sounds when decellerating above 45 mph as the last noise to fix. Again Advance Adapters thinks its my driveline angles.
Imped 02-03-2014 08:03 AM
Rear pinion angle does look low. Measure the pinion angle and measure the drive shaft angle. What's the difference?
Do the same on the front. What's the difference?
Got any physical contact between the drivetrain, tub and/or exhaust?
M1ark 02-03-2014 05:16 PM
2 Attachment(s)
Rear Drive Shaft 23 degrees. Rear Pinion 14 degrees. Rear TC output 13 degrees.
Attachment 1057433
Front Drive Shaft 12 degrees. Front Pinion 5 degrees.
Attachment 1057441
What do you guys think? Advice?
The time now is 06:43 AM.
