New to LJ - JeepForum.com
post #1 of 9 Old 08-02-2010, 10:21 AM Thread Starter
rbarrett
New to LJ
I'm putting a 2" spring spacer on my 04 LJ. Since I used to have a YJ, this is new to me. Naturally, the sales guy said I wouldn't have any vibration problems due to the longer wheelbase. Is this correct? The Skyjacker kit I'm using only has the spacers and bump stop extensions. Do I need to be concerned about the sway bars using the stock locations?? Thanks.
rbarrett is offline
post #2 of 9 Old 08-02-2010, 10:25 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you'll be fine on vibes. do JKS discos in front...you'll end up destroying the stupid ball link on the fronts anyway. hopefully that Skycrapper kit comes with shocks right?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 9 Old 08-02-2010, 12:04 PM
Kulae
Kulae's Avatar
I installed the 2" BB on my LJ. No vibe problems at all from the install. And in my opinion, it's a well needed add on for the LJ's. It definitely makes it look right/normal.
2006 Jeep Wrangler Unlimited Silver with a 6 Speed Manual
Jeeperman Winch Ready Front Bumper with Mile Marker PE8000 and 150W KC Daylighters
Body Armor Rear Bumper Swing Away and Matching Rocker Guards
Skyjacker 2" BB, 1.25" JKS BL and 1" JKS MML
75 WX ST CB radio with a 4' Firestik antenna
1.5" Seat risers custom made
33x12.5x15 BF Goodrich T/A and Procomp Rockcrusher Series 99 rims
Kulae is offline
post #4 of 9 Old 08-02-2010, 03:26 PM Thread Starter
rbarrett
Thanks for the replies. No, I bought the "cheap" kit. Spacers only. I am on the "sch-tupid, oh did that break" plan. If the shocks blow, I get to buy new ones!!! Since I'm used to a YJ and no sway bars, are they needed on the coil spring suspension? Especially the rear.
rbarrett is offline
post #5 of 9 Old 08-02-2010, 03:32 PM
Imped
Imped's Avatar
Sway bars are absolutely needed with coils. Coils are softer and don't have a locating element like leafs do. Keep the rear sway bar connected at all times and you can either disconnect the front (allows articulation but doesn't allow stability and control) when wheelin or get a Currie Antirock sway bar, which is the best option.
OlllllllO
IndyORV
Imped is offline
post #6 of 9 Old 08-02-2010, 04:05 PM Thread Starter
rbarrett
Thanks for the guidance.
rbarrett is offline
post #7 of 9 Old 08-03-2010, 09:22 AM Thread Starter
rbarrett
More confusion
With the spring spacers adding 2", shouldn't the sway bars need a similar spacer to maintain the correct relationship?????
rbarrett is offline
post #8 of 9 Old 08-03-2010, 09:37 AM
Unlimited04
read post #2.
on the rears, the sway bar won't get anywhere near binding because you're stock shocks with the BB will be so much of a limiting factor. you should buy new shocks. Skyjacker Hydros are cheap....
Useful Write-Ups:
Funny:
post #9 of 9 Old 08-03-2010, 03:55 PM
asknight
4 cylinder TJs don't come with rear swaybars.
Edit: I'm sorry, I just realized we're discussing LJs here and I don't quite think that Jeep made a 4 cyl LJ.
(A 4cyl VM 2.8L TD would be the cat's meow though)
asknight is offline
lj , wrangler , vibrations , lift , spacers
