new lift.. dosen't seem to flex - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > new lift.. dosen't seem to flex
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 03-26-2008, 01:19 PM   #1
drew76924
i got my new lift and tires on. its the FT 3" with 1 1/4 spacers for now with 35's.. i'm netting about 3.5 -4 on the lift and it just dosen't seem to flex out i'm not sure why. i don't know if it has somethign to do with the newly installed 8.8 in the rear or what but i can't get it to flex out very well.
RIP: 97' TJ on 35's (rolled)
03' Mustang GT Turbo Vert
drew76924 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 01:22 PM   #2
Crashnburn80
What shocks did you get to go with the FT 3" kit?
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 01:23 PM   #3
$lick
well 35's on a 3 inch lift isnt gonna let you flex gigantically.
post some pictures, are you disco'd? and like stated above if your shocks are bottoming out, its gonna stop your arms from traveling and flexing
1997 Wrangler 2.5L 5spd
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
Teraflex adjustable front trac bar
JKS Disco's
Axle specs:
Dana 30- Superior 4.88's
Detriot tru-trac locker
Dana 35- Superior 4.88's
Riding on:
33x12.50 BFG A/T
Black Cragar soft 8's
$lick is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 01:24 PM   #4
FLATFENDER54
sway bar connected?
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEzhttp://i73.photobucket.com/albums/i2...d/DSC01873.jpg
1954 WILLYS CJ3B (under construction) http://i73.photobucket.com/albums/i2...4/DSC01301.jpg
FLATFENDER54 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 01:29 PM   #5
Dravintoad
Did you get your mounts relocated yet?
Nothing to see here.
Move along.
Dravintoad is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 01:32 PM   #6
slate210
Did you ever clear up your issues with the mounts on the 8.8?
2000 TJ 4.0 5-SP 115k mi. Patriot Blue - Bone stock...for now.
1997 TJ 4.0 5-SP 134k mi. Red Jeep Club Member #450 - Some mods...
NJJA - New Jersey Jeep Association
2006 VW Jetta TDI DSG 54k mi. BLACK Rocketchipped, boostvalve, boost gauge.
slate210 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 01:38 PM   #7
speedydave
Did you disconnect the sway bars? having 35's 3"-4" lift is not a lot of room for flex. Is it binding or anything?
speedydave is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 01:43 PM   #8
drew76924
ya i got the shock mounts moved and everything got that squared away. there sittign right at 35 degrees. and i wasen't even on the bump stops so i know that that is not the issue and i did haev it discoed. (well to be honest only on one side cuz the stupid FT swar bar discos are horrible, i'm going to order some JKS's) so that could be the culprit but it just didn't seem right. i'm runnign the FT 3-4" shocks do u think the shocks are too short?
Unread 03-26-2008, 01:52 PM   #9
FCPremixx
I have the FT 3" kit with just the basic shocks that i came with and it flexes like crazy. The rear is a little on the stiffer side but the front will go anywhere. I'm not sure what to tell you but i know that the kit does in fact flex.
FCPremixx is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 01:55 PM   #10
bigV
can you post pics?
www.hd4w.org
High Desert 4 Wheelers
bigV is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 01:57 PM   #11
bigV
I'd say so
www.hd4w.org
Unread 03-26-2008, 02:39 PM   #12
drew76924
i will go and try it and take some pics..
Unread 03-26-2008, 05:23 PM   #13
flatlander757
So you have 3" springs with 1-1/4" spacers? I dunno about your Jeep but I netted at least 3.5" of lift with FT springs alone, so you're likely sitting at about 4-1/2" of lift... on short arms.
You really should have long arms with that much lift. Make sure you're disconnected as well.
I would trade out the BB spacers for a body lift if you are indeed talking about spring spacers.
Also, if they are spring spacers, do you still have the FT 3" shocks? You'll need some 4.5" lift shocks to maximize flex.
And you really need to disco your swaybar... mine is fantastic when disco'd.
My passenger side front spring was unseated and about 2 inches away from falling out.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 05:57 PM   #14
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Drew,
What is the limiting factor when it droops?
Are the shocks fully extended?
Are the lower control arms hitting the axle brackets?
Wheelin98TJ is online now   Reply With Quote Quick reply to this message
Unread 03-26-2008, 06:28 PM   #15
NoUse328
Originally Posted by Wheelin98TJ View Post
Drew,
Brake lines?
NoUse328 is offline   Reply With Quote Quick reply to this message
