New to Jeeping - JeepForum.com
post #1 of 21 Old 07-16-2017, 11:44 PM Thread Starter
Isaiah_a
New to Jeeping
I have a 1998 tj jeep wrangler was looking to put a 4.5" lift kit on it. I wasn't to sure what all that I needed as well as the kit itself if anyone knows and could help me out. I already have a new rear axle and am looking for a new front axle because I've read that the axle shafts on dana 30's and dana 35's tend to break.
Isaiah_a is offline
post #2 of 21 Old 07-17-2017, 12:20 AM
TheBoogieman
JEEPS ROCK!
TheBoogieman's Avatar
Welcome to JF. It really depends what you use your Jeep for and how much money you want to spend. Savvy/Currie if you have deep pockets. Zone 4.25" combo lift if you don't.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #3 of 21 Old 07-17-2017, 08:31 AM
biffgnar
biffgnar's Avatar
Let's back up and ask what size tire you want to run and what your budget is.
Romney in 2020!
biffgnar is offline
post #4 of 21 Old 07-17-2017, 08:36 AM
NotURMailman
NotURMailman's Avatar
Yes, biff is exactly right. A lot more info is needed for us to give you good advice here.
What is your goal tire size?
What type of wheeling do you want to do?
What is your budget?
A lot of people have made the TJ front D30 work and live with some upgrades under a lot of conditions.
It will also help if you fill in the Jeep info in your profile so we know more about what you're working with.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #5 of 21 Old 07-17-2017, 10:36 AM
tworley
tworley's Avatar
A set of chromos would help with the front. So far my d30 has held up pretty well minus a cracked control arm bracket. A d44 is made from the same stock, but a little bit bigger R&P and 30 spline shafts.
Colorado Member 307
tworley is offline
post #6 of 21 Old 07-17-2017, 12:25 PM
Bdk4life
With that much lift you will HAVE to get a CV (Double Carden) drive shaft and a SYE (Slip Yoke Eliminator) to compensate for the new angle of the drive shaft
Bdk4life is offline
post #7 of 21 Old 07-17-2017, 12:46 PM
Ross
of you want tires that need that much lift and you have a dana 35 you are looking for trouble.
I would think harder about upgrading your rear end before getting larger tires that you would need a 4.5 inch lift for.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #8 of 21 Old 07-17-2017, 09:36 PM Thread Starter
Isaiah_a
Sorry I failed to mention I just got a jk dana 44 with all chromoly parts and 4.88 gear ratio.
Isaiah_a is offline
post #9 of 21 Old 07-17-2017, 09:38 PM Thread Starter
Isaiah_a
Tire size and budget
I just bought an all chromoly jk dana 44 with 4.88 gear ratio and was looking to run 35" tires.
Isaiah_a is offline
post #10 of 21 Old 07-18-2017, 05:46 AM
NotURMailman
What is your intended usage of the Jeep and what kind of budget are you looking at?
What is your mechanical skill level? How much of the work will you be able to do yourself?
post #11 of 21 Old 07-18-2017, 06:46 AM
biffgnar
biffgnar's Avatar
This is a front or rear D44?
Romney in 2020!
biffgnar is offline
post #12 of 21 Old 07-18-2017, 10:58 AM
tworley
tworley's Avatar
And know that the JK is not bolt in...
Colorado Member 307
tworley is offline
post #13 of 21 Old 07-18-2017, 11:02 AM
biffgnar
biffgnar's Avatar
Absolutely, in particular if it is a front.
Romney in 2020!
biffgnar is offline
post #14 of 21 Old 07-19-2017, 12:59 PM
Bdk4life
X2 on the D30 up front. Are you going to rock crawl very hard, or are you mostly in sugarsand/mud? Are you going to run a locker in the front? This might get us a better idea of if the D30 swap is necessary or if you can get away with building up your current 30. C gussets and chromo shafts can go a long way with a D30 upfront.
Bdk4life is offline
post #15 of 21 Old 07-19-2017, 01:07 PM
biffgnar
biffgnar's Avatar
C gussets in TJ D30s are not necessary. TJ D30s lived for years without anyone even considering gussets. JKs come along with bigger Cs, wider axles and more weight (i.e. greater leverage) and start having problems and suddenly TJ people think more is better. How often do you really hear about bent Cs in a TJ?
Romney in 2020!
biffgnar is offline
