Quantcast new to the jeep world, many questions. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > new to the jeep world, many questions.
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 03-04-2008, 02:34 PM   #1
jimG16
Just recently turned 16 and got my first car. A black 2002 jeep wrangler X, its manual. The tires on the jeep now are 31"s or "were" 31"s. They are way worn down and I just bought some 33 inch maxxis bighorns, so everything works out. Now, my jeep already has a 2-3 inch lift, not completely sure and everyone I've asked said exactly "2-3 inches." Which should leave me with just enough lift, I think. Will me buying a 2" body lift be to much total lift for my jeep with 33"s on it? It will give me great clearance but I'm worried that having a lot of space in the wheel well will look ugly. Opinions please
thanks.
-jim
jimG16 is offline   Reply With Quote
Old 03-04-2008, 02:39 PM   #2
Benderff
intentionally left blank
Benderff's Avatar
Welcome to jeep ownership. Hope you have a good after school job to pay for all the stuff you will want, and "need". haha Most people only do a 1'' body lift as anything more looks lame, and other issues. With a 2'' lift and a
1" bl you will be fine for runnning 33's. I'm sure you will have some rubbing off road though.
Benderff is online now   Reply With Quote
Old 03-04-2008, 02:47 PM   #3
jimG16
Ha indeed I do, have money saved and what not. Its burning a hole in my pocket, but I don't want to buy something completely unnecessary. With body lifts I've read that you have to buy new a/c lines, gas tank filler tubes, radiator drop down brackets, etc. Will I run into any similar problems with a 1" bl?
Old 03-04-2008, 02:48 PM   #4
jb4
google4
jb4's Avatar
with a 1" BL there should be enough slack in the hoses. I'm not totally sure on the fan shroud though.
jb4 is offline   Reply With Quote
Old 03-04-2008, 02:49 PM   #5
sbulla
Well, the FIRST thing you have to learn is...it's not a "car"...it's a Jeep! ;-)
Just thought I'd warn you before too many postings here.
Welcome and good luck with the new money pit!
Sonny
'06 Unlimited
sbulla is offline   Reply With Quote
Old 03-04-2008, 02:53 PM   #6
mall0y
Try to take some pictures of the suspension and body. That way we can figure out what kind of lift that you have. If it had 31's on it I'm going to lean towards a 2"BB. Pictures would be really helpful though
1997 TJ - 3" FT, 31's on Crager Soft 8's, SYE/CV Drive shaft, RE Adj. UCAs, 2 Hella 550FF's, Dual tops...
mall0y is offline   Reply With Quote
Old 03-04-2008, 02:55 PM   #7
jimG16
I gotcha, you won't catch me making that mistake again. ;-)
Old 03-04-2008, 02:57 PM   #8
jimG16
Ill go out right now, hold on. Ill have them up in like 15-20 minutes.
Old 03-04-2008, 02:57 PM   #9
Crashnburn80
You do not have these problems with a 1" BL, the only thing that need adjusting is the radiator fan shroud and possibly your Tcase linkage. Greater than 1.25" and it looks fugly and more things need to be tinkered with.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Old 03-04-2008, 03:01 PM   #10
BigPoppaG
Getting ready to do that to mine. With a 2BB" lift and a 1.25"Body lift the 33's" will be fine.
You are one of the lucky ones to Get a Jeep for your first Vehicle. Have fun with it!
1998 4.0L Sport
4.5" SUPERLIFT, Warn Skid Plate, Trail Gear Rock Sliders, JKS Disco's
STEELERS RULE!!!
http://bigpoppag.blogspot.com/
http://www.mpjai.com/
BigPoppaG is offline   Reply With Quote
Old 03-04-2008, 03:04 PM   #11
TimBrown
I have a performance accessory 1 inch BL and it is great. The kit came with the necessary parts to relocate the fan shroud and also a new bracket for the transfer case. I didn't actually have to use the parts for relocating the fan shroud. I had more than enough clearance with out it. The TC bracket was a little tricky. You might have to adjust the 4wd shifter once you get it installed to make sure you comfortably can get into 4hi and low. There is an adjustment screw on the linkage and it is real easy to do. Welcome to the wonderful world of jeep. Be ready to spend a lot of money but it is all worth it. Can't wait to see the pics.
TimBrown is offline   Reply With Quote
Old 03-04-2008, 03:04 PM   #12
DaOne
x eleventy billion
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline   Reply With Quote
Old 03-04-2008, 03:09 PM   #13
ToyTJ
[QUOTE=jimG16;4901217]It will give me great clearance but I'm worried that having a lot of space in the wheel well will look ugly. Opinions please
thanks.
Take a look at my gallery to see what 33" Big Horns look like on a black TJ with a 4" suspension lift. No body lift. I did spray the frame and inner fender wells with Rhinoliner because of the gap - looks good, I think.
PS. Click on the thumbnails for a larger view.
'97 TJ Sport, 4.0, 5 spd, black, saddle interior, RC 4" lift, 33x12.50 Maxxis Big Horns, Pacer 15x10 wheels, OME shocks, tube bumpers, side bars, Rhinoliner in and out, Safari Doors, Pioneer/Kenwood sound
ToyTJ is offline   Reply With Quote
Old 03-04-2008, 03:11 PM   #14
gily25
www.quadratec.com www.4wd.com www.jcwhitney.com you'll need those once you start breaking stuff...ha!
iPhone app user; excuse typos...thanx.
gily25 is offline   Reply With Quote
Old 03-04-2008, 03:25 PM   #15
gijoeyb
2010 JK Wrangler
welcome, try and look through this http://www.jeepforum.com/forum/f9/what-does-my-tj-look-like-lift-46712/ for other pics as well. i would also recommend you see if there is local club in your area. once you get to know the members AND if you are nice, you might be able to see their rides up close and possibly take a test ride with them. i'm not a fan of the body lift, but i have seen 33s on a stock jeep and depending on what you want to do with the jeep, that may or may not be a healthy combo... until you go with a larger lift/tire. another easy way to tell for yourself, is check out a stock jeep and eyeball suspension parts. again, welcome and hope you have fun with your jeep
gijoeyb is offline   Reply With Quote
Glock Forum
