New to jeep. shaking terribly and knocking sound - JeepForum.com
post #1 of 11 Old 10-27-2013, 04:10 PM Thread Starter
mvaafc1
Hi everyone I bought a 2000 sahara in March. I recently ran into an issue where my car is shaking terribly and making almost like a knocking sound as well as the check engine light came on. I can't figure out what it is. Got a tune up and oil change. Any ideas?
mvaafc1 is offline
post #2 of 11 Old 10-27-2013, 04:55 PM
Turcsi_Wheeler
I might be very wrong, but do the motor mounts looks good?
Turcsi_Wheeler is offline
post #3 of 11 Old 10-27-2013, 05:14 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Wrong section moving to proper area
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 11 Old 10-27-2013, 05:26 PM
tyvanwie
Do you know if the two are related? Do you feel the shaking in the steering wheel?
tyvanwie is offline
post #5 of 11 Old 10-28-2013, 07:51 AM Thread Starter
mvaafc1
Yes they do
mvaafc1 is offline
post #6 of 11 Old 10-28-2013, 07:54 AM Thread Starter
mvaafc1
No not in the steering wheel, the entire car shakes but it doesn't do it all the time
mvaafc1 is offline
post #7 of 11 Old 10-28-2013, 08:03 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Welcoming to being a Jeeper!!
I've read that if the injectors are dirty they can load up and dump a bunch of fuel at once which would cause a rough idle/jump in RPM's that can cause a shake. The lean/rich condition this would cause could also be the reason for your check engine light. Did you have the code read? Most auto parts stores will do this for you for free these days. You could try a bottle of injector cleaner in the gas tank and see if that helps. Good Luck!
-Ryan
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #8 of 11 Old 10-28-2013, 08:07 AM Thread Starter
mvaafc1
Thanks ryan, and yes the code read p0303
mvaafc1 is offline
post #9 of 11 Old 10-28-2013, 01:49 PM
tomsrancho
tomsrancho is offline
post #10 of 11 Old 10-28-2013, 07:20 PM
JStMarie
JStMarie's Avatar
I've experienced an extreme version of what you are describing when I had a blown head gasket. Coolant was getting into the cylinder, causing a terrible misfire, which in turn caused shaking of the entire vehicle.
Pull the plug that is misfiring and shine a very bright light down into the plug hole. If you see green, ouch.
Good luck.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
post #11 of 11 Old 11-11-2013, 11:58 AM
JStMarie
JStMarie's Avatar
mvaafc1, how did this turn out?
JSt.Marie
JStMarie is offline
