New Jeep Owner need some help!!!! Mismatched gear ratios? - Page 2 - JeepForum.com
post #16 of 28 Old 09-17-2011, 09:11 PM Thread Starter
Jeeper_joe
So I pulled the covers off to day and it's true... I have 4.88s in the rear and what appears to be 3.73 in front which doesn't make any sense to me because I thought it would be 4.10 if anything... Maybe I didn't calc it right so correct me if I'm wrong but in front there are 41 teeth on ring gear and 11 on pinion gear which comes to 3.727?????
98 TJ 4cyl, 4" lift ,35s, super 35-lock rite, smitty armed all the way around....SOLD
99 Sahara, 4" lift, 35s, 8.8, 4.56s, Detroit locker......SOLD
Looking for new project
Jeeper_joe is offline
post #17 of 28 Old 09-17-2011, 09:38 PM Thread Starter
Jeeper_joe
post #18 of 28 Old 09-18-2011, 12:20 AM
MATT99TJ
The manual 4 banger should have come with 4.10s. My guess would be the previous owner swapped the front axle and never changed the gears. Maybe you got lucky and have a HP 30?
MATT99TJ is offline
post #19 of 28 Old 09-18-2011, 06:40 AM
Kip03TJ
This is exactly why when people ask if they can just regear the rear first and do the front later I say you shouldn't. The previous PO (or POS) never regeard the front and you're stuck with paying to regear. And it's gonna cost you some bills..
FOR SALE
14,960 miles perfect condition
2003 Jeep Wrangler Sahara edition fully loaded 5 speed manual. Brown dog 1" motor mounts, Currie 1" body lift, jks front disconnects, 31" Goodyear Wrangler duratracs, 8 adjustable control arms, Advance Adapters HD SYE, Tom woods premium driveshaft, driver & passenger heated seats
Kip03TJ is offline
post #20 of 28 Old 09-18-2011, 07:39 AM
RowJ
Yup, stinks that they never told you about only regearing rear!
Good catch... that you notices it before causing serious damage...hopefully!
That's why I removed front drive shaft till I could regear front axle the way I wanted to.
Sounds correct, but I always just count drive shaft revolutions.... easier!
RJ
RowJ is offline
post #21 of 28 Old 09-18-2011, 12:00 PM
Necko2529
Necko2529's Avatar
Sounds like you rescued that TJ from the PO.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #22 of 28 Old 09-18-2011, 06:50 PM Thread Starter
Jeeper_joe
whats an HP 30? and how would i tell?
and yes i did rescue it... the PO didnt have a clue but im not sure if it was him or the person before him that jacked with the axles, either way doesnt make much sense to me. anyone else have any other idea about the 3.73 in the front? and obviously im lookin for some 4.88s if anyone knows of some i can pick up
post #23 of 28 Old 09-18-2011, 07:16 PM
Necko2529
Necko2529's Avatar
It could be that the axle was swapped in from an xj. A High Pinion D30. In a high Pinion axle the Pinion sits above axle centerline.
post #24 of 28 Old 09-18-2011, 08:31 PM Thread Starter
Jeeper_joe
hey guys just had a guy offer me a super 35 kit for $400 is this a good deal? i know i need to focus on getting gears for the front but is seems like to good of a deal to pass up what do you think?
post #25 of 28 Old 09-19-2011, 06:43 AM
RowJ
Not always! Depends on what's included??
http://www.quadratec.com/products/52400_1200_07.htm
http://www.quadratec.com/products/16120_110X_PG.htm
RJ
RowJ is offline
post #26 of 28 Old 09-19-2011, 11:10 AM Thread Starter
Jeeper_joe
its superior axles, detroit locker and shims. and local shop that always works on my stuff said they would install rear axles and locker and front gears and locker for $500.00
post #27 of 28 Old 09-19-2011, 01:55 PM
Kip03TJ
Do it
And give me their number
FOR SALE
Kip03TJ is offline
post #28 of 28 Old 10-11-2011, 08:55 PM Thread Starter
Jeeper_joe
Well it's been a while but I got a locker and superior shafts in the rear and now have matching 4.88s FINALLY. Now time to go break something.....
35s , gears , tj
Gear ratios Jacola11 TJ Wrangler Technical Forum 2 07-13-2010 04:24 PM
gear ratios thewrangler84 TJ Wrangler Technical Forum 5 03-25-2010 08:44 PM
New Jeep Owner - How can I tell which gear ratio I have and other questions. wwcenturion TJ Wrangler Technical Forum 5 11-27-2007 10:24 PM
Gear Ratios aaronswb2 TJ Wrangler Technical Forum 6 10-08-2005 06:55 PM
Help! - New Jeep Guy Needs Help with '92 YJ Gear Ratios Missin44 YJ Wrangler Technical Forum 1 03-04-2002 10:05 AM
