New Jeep Owner need some help!!!! Mismatched gear ratios? - JeepForum.com
post #1 of 28 Old 09-15-2011, 09:32 PM Thread Starter
Jeeper_joe
hey guys just got a 97 TJ 2.5L 5spd with 147k for basically $3k, nice jeep so far. It has aftermarket bumpers, 4'' lift with 35's, stock axles, and im pretty sure it has 4.88 gears out bk and 4.10s up front though i havent pulled the covers off yet to make sure, u can feel some binding in 4wd that im sure isnt normal.... basically im totally new to wheelin a jeep decently machanically inclined and need some advice on where to spend money affectively.........
ANY advise is very much appreicated
Jeeper_joe is offline
post #2 of 28 Old 09-16-2011, 04:49 AM
Dolfy
Dolfy's Avatar
If you have different gearing in the front axle then that is where you need to spend your money first. Your axles need to match and if they don't and you use your 4wd you can really screw it up. You should find out what you have in your axles first before you use it in 4wd.
You may also want to read this thread about running 35's on a d35.
http://www.jeepforum.com/forum/f9/35...-bomb-1262916/
'00 Blue TJ Sport & '08 Red KK Sport (OIIIIO)
Blue Jeep Club member #170
Thought for the day:
Some people are like Slinkies... They don't really have a purpose, but they still bring a huge smile to your face when you push them down a flight of stairs.......
Dolfy is offline
post #3 of 28 Old 09-16-2011, 06:29 AM
mikesbeachhut
Jack both front tires off the ground and count how many times the front drive shaft goes around for 1 tire revolution.Write it down.Now do the same for the back wheels.Write it down and compare it to the front.Should be the same.
mikesbeachhut is offline
post #4 of 28 Old 09-16-2011, 07:19 AM
NotURMailman
NotURMailman's Avatar
First statement explains the second. You need to check/varify your gearing. If you are correct about the gears I would recomend removing the front driveshaft until you re-gear the front diff to match the rear.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #5 of 28 Old 09-16-2011, 08:10 AM
RowJ
[.... u can feel some binding in 4wd that im sure isnt normal....
Two different gear ratios would explain that!
Good advice from 'noturmailman'. Do not drive in 4WD till you know for sure!
Will get expensive quickly!
If different gears, remove front drive shaft. Easy to do with a 1/4" ratchet set and a 6" extension..... 20 min the first time.
RJ
RowJ is offline
post #6 of 28 Old 09-16-2011, 08:53 AM
danielbuck
1946 CJ2
when you say you can feel it 'binding', is this when you are turning? or when you are going straight? You have tried putting it in 4wd already? if you survived that, then I imagine they are the same ratios.
If it's when you are turning (on concrete) this is probably normal to feel some tightness while turning sharply in 4wd.
But man I would imagine if there really were different ratios in front and rear, in 4wd on concrete you probably wouldn't be able to move a foot forwards or backwards without serious tire chirping/hopping, I imagine you would know immediately (and probably break something?) as soon as you slam it into 4wd. Just guessing on that though.
Would you be able to tell without jacking the vehicle up, and just by simply counting how many times both driveshafts turn while slowly rolling forward in 2wd? both driveshafts should rotate the same amount of times per given distance, correct? Or would it just be easier to jack up the front and rear and do it that way?
danielbuck is offline
post #7 of 28 Old 09-16-2011, 09:12 AM
LOCAL
RJ
As stated above this post if you even think you might have different gearing in your axles, do not drive at all unless the front driveshaft is removed. But i would think if you had 4.88 in the back and 4.10 in the front something would have already broken.
On a different note, unless you know the maintenance history i would spend some money there. Go over the whole jeep check for worn suspension and drivetrain, and steering components, leaking oil seals things like that. Change transmission fluid, transfer case and differential fluid, flush the coolant, brake fluid, plugs, filters, and all that fun stuff.
LIVEforTODAY
LOCAL is offline
post #8 of 28 Old 09-16-2011, 10:31 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
... remove front drive shaft. Easy to do with a 1/4" ratchet...
Is it 1/4"?
I think they are 3/8".
Wheelin98TJ is offline
post #9 of 28 Old 09-16-2011, 10:33 AM
LOCAL
Originally Posted by Wheelin98TJ View Post
Is it 1/4"?
The bolts are like 9mm i believe. i think he was saying use a 1/4 inch drive ratchet
LIVEforTODAY
LOCAL is offline
post #10 of 28 Old 09-16-2011, 10:38 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Is it 1/4"?
He means use a 1/4" drive ratchet with a 6" extension and the correct 5/16's or 8mm socket. Need more coffee?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #11 of 28 Old 09-16-2011, 11:11 AM
Wheelin98TJ
JEEP FREAK
Wow, I'm slow today. I don't drink coffee, but maybe I should start.
I thought it was 8 mm, but the math wasn't adding up with my 3/8" guess.
post #12 of 28 Old 09-16-2011, 11:52 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Jeeper Joe, are you noticing the binding/steering feedback after you've shifted into 4x4 while you're driving on pavement? If so, that's your issue as you cannot use the Wrangler's part-time type of 4x4 system on pavement. Your Wrangler's axles are mechanically locked together whenever you're in 4Hi or 4Lo which means the front axle's tires will not be allowed to rotate faster than the rear tires through a turn as they must be able to do. Only a Full-Time 4x4 system like is available on a Grand Cherokee can be used on pavement. Wranglers do not have a full-time 4x4 system available, they only come with offroad-only part-time 4x4 systems.
The good news is that the Wrangler's part-time 4x4 system is a far more aggressive 4x4 system which is better offroad than a street-oriented full-time 4x4 system is.
Try your 4x4 out on dirt and see how it feels then. The dirt surface will allow the front and rear tires to turn at the different rpms they need to during even slight turns. I'd be very surprised if the rear axle was regeared to 4.88 and the front was left at 4.10.
Jerry Bransford is online now
post #13 of 28 Old 09-16-2011, 12:02 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
that ratio is different enough that "some binding" wouldn't even begin to describe what would happen if those ratios were correct.
i suspect you were simply feeling the wind up that happens when you try driving around on a hard surface in high range.
ratmonkey is offline
post #14 of 28 Old 09-16-2011, 12:05 PM
RowJ
... reason i think they are different is ...... put it in 4wd a few times on sand but on grass or gravel u can just hear the tires slippping alot. so no more 4wd for me until i figure that out
He posted twice. This is from other thread.
Suspect he got no response to first time posting..... waited an hour..... posted again.
RJ
RowJ is offline
post #15 of 28 Old 09-16-2011, 12:25 PM Thread Starter
Jeeper_joe
thanks for all the fast replys everyone. and i havent locked it in 4wd on pavement but the binding is when driving straight not just when turning so im gonna pull the covers off this weekend and look everything over real good and change fluids. ive already changed tie rod ends and a few small things but everthing else seems to be in pretty good shape. besides my steering gear box leaking and feeling a lil sloppy
sorry for the double post by the way wasnt sure if it was in the right spot or not..
35s , gears , tj
Gear ratios Jacola11 TJ Wrangler Technical Forum 2 07-13-2010 05:24 PM
gear ratios thewrangler84 TJ Wrangler Technical Forum 5 03-25-2010 09:44 PM
New Jeep Owner - How can I tell which gear ratio I have and other questions. wwcenturion TJ Wrangler Technical Forum 5 11-27-2007 11:24 PM
Gear Ratios aaronswb2 TJ Wrangler Technical Forum 6 10-08-2005 07:55 PM
Help! - New Jeep Guy Needs Help with '92 YJ Gear Ratios Missin44 YJ Wrangler Technical Forum 1 03-04-2002 11:05 AM
