New jeep owner! (exhaust leak and oil leak) - JeepForum.com
post #1 of 10 Old 03-01-2010, 09:41 AM Thread Starter
Mindcrime13
Hello guys!
Im new to the forum, this is my first post but i have read a lot here and found tons of useful info, well i just got myself into a jeep for the first time, i come from the mustang world, but have always like the jeeps, so i sold the mustang and got a 2006 65th anniversary wrangler, for 16k it only has 45k miles
i drove it this weekend across the island (im from PR) the jeep held up great, when i got home i checked everything and the only 2 issues i found were, some oil dripping thru the sides of the oil pan, im thinking it could be the gasket from the oil pan, but also saw some oil coming from the oil filter, so idk,
the other issue is that i think i have a exhaust manifold leak, but im not sure, (the mustangs are known for the manifold cracking at the flange, so im a bit familiar with the leak sound) i got a video of the sound so you guys could tell me if that is normal or if its a leak , you can hearlyy clearly on 0:12
thanks for your help!!
YouTube - Sound
Mindcrime13 is offline
post #2 of 10 Old 03-01-2010, 09:49 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
It doesn't sound like an exhaust leak to me.
It sounds more like the normal noises you hear from a 4.0 I6.
Wheelin98TJ is offline
post #3 of 10 Old 03-01-2010, 09:53 AM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
The oil might have just ran down the pan when the filter was changed.
TheBoogieman is offline
post #4 of 10 Old 03-01-2010, 10:02 AM
mdm
Farm Wheeler
Sounds pretty normal to me. The oil could well be coming from the filter. When the filter is changed you usually get some oil that spills and runs down the side of the block. If it's not cleaned up well it can puddle on the bottom flange of the block and run down the side of the pan. If the rubber gasket on the old filter stuck to the block and wasn't removed before installing the new filter you'll usually get a leak. An over tightened filter can leak.
Clean the engine well and watch for the source of the oil.
Welcome to the forum and the world of Jeeps.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #5 of 10 Old 03-01-2010, 12:16 PM Thread Starter
Mindcrime13
ok! hm i thought that the sound from 0:11 till the end of the vid could be a leak, but if that's normal, ill get use to it!
also these a sort of whine in the power steering pump pulley when i accelerate, can i put some wd40 on it?
thanks for your help guys!
post #6 of 10 Old 03-01-2010, 03:27 PM Thread Starter
Mindcrime13
what benefits can i get from a header also? i found this one locally for a really good price:
it already have the gasket, do i have to change anything else if i change this?
post #7 of 10 Old 03-01-2010, 03:40 PM
Wheelin98TJ
JEEP FREAK
On a stock I6, very little benefit.
I'd consider it a gamble and not a very good one. You may have cracking problems with that header, probably more likely than if you kept the stock manifold.
The stock 2 piece manifold has a good record for holding up. The aftermarket headers for the 4.0 I6 do not have such a good record, but its mostly the 1 piece headers that fail.
Not many people are using the headers like you posted above because the 2 piece factory manifolds are holding up so well.
post #8 of 10 Old 03-01-2010, 07:03 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Good advice...
Knuckelhead is offline
post #9 of 10 Old 03-01-2010, 08:05 PM Thread Starter
Mindcrime13
Thanks for all the advice guys, one last question is a whooshhhh hallow kind of sound , like when you blow an empty glass bottle normal? It goes away when accelerating
post #10 of 10 Old 03-04-2010, 02:34 PM Thread Starter
Mindcrime13
i just found the whoosh issue, its the belt, its stretch, i saw a thread on how to inspect the belt, with the 2 line in the tensioner and im almost in the first line, also notice that the tensioner swings up and down a bit, its this normal?
New Rubicon owner, new lift, new leak... HunterW TJ Wrangler Technical Forum 6 02-05-2010 04:04 PM
exhaust leak between header and exhaust piping 03rubiconMG TJ Wrangler Technical Forum 7 06-11-2009 09:02 AM
Tranny Leak, any common place for a jeep to leak jb1dsl TJ Wrangler Technical Forum 6 03-23-2006 11:09 AM
rear main seal leak and exhaust leak? paroxysym TJ Wrangler Technical Forum 6 01-30-2006 01:46 PM
Exhaust Leak jfarrell YJ Wrangler Technical Forum 1 04-25-2002 07:11 PM
