New jeep lift help?? - JeepForum.com
post #1 of 4 Old 11-10-2011, 06:18 AM Thread Starter
Jeeper_joe
Hey guys I just sold my 97 4 banger and bought a 6 cyl Sahara and it is supposed to have a 4" lift just like my old tj but it looks and feels a lot shorter. This jeep has 33"s where mine had 35s but it shouldnt make that much of a difference. My ?s are 1. How can I tell if it was a 4" lift and 2. Can I just put new 4" springs under it to pick it up? It has a drop pitman arm and extended sway bar links so any help is greatly appreciated......
98 TJ 4cyl, 4" lift ,35s, super 35-lock rite, smitty armed all the way around....SOLD
99 Sahara, 4" lift, 35s, 8.8, 4.56s, Detroit locker......SOLD
Looking for new project
Jeeper_joe is offline
post #2 of 4 Old 11-10-2011, 08:00 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Post pics.If it has a drop pitman arm,most likely it's a 4" lift.If it doesn't have an adjustable track bar with a frame side drop also,remove the drop pitman arm and go back to stock.You can just replace the 4" springs IF it has a 4" lift.
http://www.jeepforum.com/forum/f9/fa...7/#post6077636
My old 05' when it had a 4" lift and 33's.
TheBoogieman is offline
post #3 of 4 Old 11-10-2011, 09:44 AM
jeep_tech7
some springs sag and arn't as big as other companys, the lift in your new jeep can be a different company if it has a drop pitman arm its most likley a 4 inch as said above throw some different springs in and you should be fine!
02 tj 4" lift 4:10 d30/35 aussie front locker 1.25bl 1"mml stinger xrc8 winch fully skidded
jeep_tech7 is offline
post #4 of 4 Old 11-10-2011, 10:02 AM Thread Starter
Jeeper_joe
Ok let me try to figure out how to add photos from a iPhone and I'm 99% sure it's got a drop pitman arm and I know it's got a tcase drop
help needed , lift
Poly Performance Jeep Jk 4" Stage 3 lift versus AEV / Nth degree 3.5 " Premium lift TDmaster JK Wrangler Technical Forum 20 02-08-2013 02:43 PM
Do I need a lift kit to lift my Jeep 3" or only shocks will do? Mitch72 TJ Wrangler Technical Forum 22 05-29-2010 11:53 AM
Bought used Jeep with OME lift, how do I tell how high the lift is? Baggerguy TJ Wrangler Technical Forum 6 01-01-2007 09:57 PM
The Jeep Fairy Modified My Jeep! (lift & tires) Overdrive TJ Wrangler Technical Forum 18 12-15-2006 12:45 AM
affordable way to lift jeep 2" without going body lift route? jimmysjeepn YJ Wrangler Technical Forum 12 11-04-2004 12:44 PM
