new gasket when changing gear oil - JeepForum.com
post #1 of 6 Old 09-28-2001, 03:23 PM Thread Starter
mytjnamedrex
im going to change out the oil in both diffs tommorrow and am wonderin if i am going to need a new gasket or will silicon work? Which is better/easier?
97 TJ w/ Hardtop/AC/5-speed/I-6/ aftermarket stereo/ 2" spacer/1"BL/ 32x11.50 BFG AT's.
....that sounds expensive..
mytjnamedrex is offline
post #2 of 6 Old 09-28-2001, 04:02 PM
Nightclaw
You won't need a gasket. Silicon sealant works just fine on it's own. Besides, if you use a gasket, that's just more crap you have to scrape off the next time. Cheers!
Nightclaw is offline
post #3 of 6 Old 09-30-2001, 02:10 PM
James Dally
You have probably done the job already but if you buy a hand pump (like a bicycle pump but fatter), you can actually suck the oil out of both diffs through the filler hole. Then you done need to even take the plate off the diff.
James Dally is offline
post #4 of 6 Old 09-30-2001, 02:57 PM Thread Starter
mytjnamedrex
thanx for the advice but i already did it and simply used some gasket maker from autozone. If i had used your idea i wouldnt have found the shavings and chunk of metal that was in the rear diff. But if i ever need to just drain it i might do it your way cause i made a pretty big mess in the garage and the entire garage smells like the burnt up gear oil that came out.
post #5 of 6 Old 09-30-2001, 04:31 PM
SunDawg
...and that's a bad thing ???
'97 Jeep TJ Sahara Edition
-RE 4.5" Lift
-BFG KO 33x10.5r15 on AR-767 15x8
-Tom Wood's Conversion Kit
SunDawg is offline
post #6 of 6 Old 09-30-2001, 04:45 PM Thread Starter
mytjnamedrex
my parents know nothing about cars and dont trust me with anything so when the garage smells like something was an fire they tend to think the worst. Plus it smells really really bad.
Changing my head gasket MSFIT TJ Wrangler Technical Forum 2 04-21-2008 12:48 PM
Need new gasket for oil plug when changing oil? Dirty Backroads TJ Wrangler Technical Forum 5 03-29-2007 05:12 PM
Changing diff cover gasket and front gasket on diff Laxstar46 TJ Wrangler Technical Forum 2 10-11-2006 07:33 PM
Changing head gasket Sfrid073 TJ Wrangler Technical Forum 0 09-06-2006 05:30 PM
Changing Oil Pan Gasket Leroux YJ Wrangler Technical Forum 1 09-08-2003 09:39 AM
