New gas tank skid plate... can you say aluminum? - Page 9 - JeepForum.com
post #121 of 927 Old 05-11-2009, 11:06 AM
SeanCucf
Praying for pre '03 engine/tc/tt combo skids. I've been waiting a long time since medic went out and others don't cater to pre '03 guys. (insert prayer smiley here)
SeanCucf is offline
post #122 of 927 Old 05-11-2009, 11:17 AM
Shakey
We have a few things. None will be conventional, or using commonly accepted materials.
Can you provide an update on if you will make a transfer case skid plate out of aluminum or some other non-commonly accepted material? I was going to have one made, but I'm guessing that buying one from you will be cheaper in the long run.
Shakey is offline
post #123 of 927 Old 05-11-2009, 12:42 PM
fromme
fromme's Avatar
How far is the top of the tank from the bottom of the tub crossmember?
It's just about one inch, maybe slightly less. The bar crosses right over the middle of the clips that hold the hard plastic lines on the driver's side on my 04. And there is absolutely no more room between those plastic lines and the A/R bar. The are rubbing as is, I had to sleeve those lines.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #124 of 927 Old 05-11-2009, 01:03 PM
john NC
john NC's Avatar
1979 CJ5
ok, i'm sold that thing looks awesome
john NC is offline
post #125 of 927 Old 05-11-2009, 01:15 PM
NotURMailman
Looks like a sweet skid! I wish I hadn't just bought/ modified/ installed my Skid Row piece...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #126 of 927 Old 05-11-2009, 03:23 PM
Mini-Me26
Originally Posted by Jerry Bransford View Post
Here's a pic of the surprisingly small box it comes in...
I don't know how much size factors into it, but I had a cell phone cost $134.79 in customs and brokerage fees.
I'll stop polluting this thread through. My next post will be before and after shots.
Mini-Me26 is offline
post #127 of 927 Old 05-11-2009, 04:46 PM
Dukes69
Dukes69's Avatar
Comparisons:
Stock Skid Weight (w/ 1/8" welded to the bottom):
Competitors 3/16 steel skid:
Savvy 3/16 aluminum skid:
My Jeep lost 7.6 pounds going from the stock skid to the Savvy skid.
AIM: Dukes69
Ya Savvy?
Dukes69 is offline
post #128 of 927 Old 05-11-2009, 05:28 PM
Flipside
Flipside's Avatar
Originally Posted by SeanCucf View Post
I've been waiting a long time since medic went out ...
Yes, I too am disappointed that the Medic is no longer... Perhaps the Savvy group will come up with a replacement for the shovel on my 06 LJ? Even better would be a design that doesn't require a BL to work its magic!
mrblaine: what say you on the issue of galvanic corrosion with your Aluminum bling?
Do something by yourself and it's called wierd. Do it with others and it's called a club.
Flipside is offline
post #129 of 927 Old 05-11-2009, 05:33 PM
Jeepguy1977
Jeepguy1977's Avatar
Galvanic Corrosion occurs in salt water when electrical current is present in the water (never moor next to a Bayliner). So does your Jeep spend a lot of time submerged? I suspect your more concerned about regular old corrosion.
And after talking to Provologear I believe that those in corrosion rich areas will also receive a bottle of Alodine to treat the aluminum with.
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline
post #130 of 927 Old 05-11-2009, 06:20 PM
chefdab
I have two questions about this skid.
1.) It was stated that it mounted to the rear cross member to keep it farther away from the track bar. Is that still the case for an Unlimited or does it mount in the stock location which leaves open space between the gas tank and rear cross member?
2.) Correct me if I'm wrong, but is there any risk of electrolysis using disimilar metals for the mounting than the skid itself?
David
2005 LJ w/ RE 5.5 LA riding on 35"MT/Rs
"Roads, where we're going we don't need roads."
... at what point has "NEED" ever come into play when it comes to Jeep upgrades
Originally Posted by ranmannm View Post
I'm a idiot so be genital.
chefdab is offline
post #131 of 927 Old 05-11-2009, 06:35 PM
emev0l
Someone start making new gas tanks that hold a couple gallons less than the stock tank, raise it up 2 inches and give it a sick departure angle. The only thing that I have seen close is tanks made for stretched Wranglers.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #132 of 927 Old 05-11-2009, 06:44 PM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I changed how I worded that point so it is clearer, it isn't mounted to the rear crossmember at all. It's mounted to the same attach points as the OE skidplate is but the way the skidplate is configured, it moves the gas tank and plate back until it is next to the rear cross-member... as far rearwards as it is possible to go.
Getting
Jerry Bransford is offline
post #133 of 927 Old 05-11-2009, 07:45 PM
robncar
robncar's Avatar
We assembled the Savvy Aluminum Gas Tank Skid tonight after work. It took my son and I about 20 minutes. Went together like butter, everything fit just fine. Can't wait to get it installed. Ours weighed 32 lbs., so light, a 12 year-old can hold it, no problem.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #134 of 927 Old 05-11-2009, 07:48 PM Thread Starter
Jerry Bransford
Administrator
I don't think your son would have any trouble holding my old heavy steel skidplate either Rob, he looks pretty darned solid. Hey, when are ya gonna buy him some shoes so he doesn't have to run around outside in his socks!
Getting
post #135 of 927 Old 05-11-2009, 07:55 PM
robncar
robncar's Avatar
That's how I afford Jeep mods... shoes are expensive!
They tell us he's going to be 6' 5", or more!!! I'm going to have to start to lift weights again, gotta keep one step ahead. He has a female cousin, on his Mom's side, that is about 6'4"; she plays basketball and volleyball in college right now. He has another cousin that's 19, that's 6'6" but rather thin; ha!
Hey Jerry, I'm waiting to run the tank dry before we do the install. It's a tip mrblaine gave us.
robncar is offline
? about gas tank/skid plate Jeepfan Jeff YJ Wrangler Technical Forum 7 01-03-2010 03:15 PM
Aluminum transfer case skid plate Wheelin98TJ TJ Wrangler Technical Forum 12 11-20-2009 10:55 AM
Savvy offroad aluminum gas tank skid plate mustgooverit TJ Wrangler Technical Forum 0 08-27-2009 12:48 AM
Gas tank skid plate Lee3333 YJ Wrangler Technical Forum 7 06-13-2008 07:32 PM
Gas tank skid plate help J13760 YJ Wrangler Technical Forum 1 04-13-2006 12:55 PM
