New gas tank skid plate... can you say aluminum? - Page 61 - JeepForum.com
post #901 of 927 Old 08-01-2011, 09:58 PM
steve578
steve578's Avatar
Finished! Much more clearance over my Safari tank. Sorry for the iPhone pics.
2013 JKUR
steve578 is offline
post #902 of 927 Old 08-01-2011, 11:37 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Nice! Did you get a before and after clearance measurement?
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #903 of 927 Old 08-02-2011, 04:40 AM
steve578
steve578's Avatar
I wish I did, but didn't think about it.
2013 JKUR
steve578 is offline
post #904 of 927 Old 08-02-2011, 06:17 AM
MCDavis
Looks good, steve!
1 question on the Genright: wasn't it basically the same amount of clearance as stock? Seems like I read that it's 1/4" higher.
MCDavis is offline
post #905 of 927 Old 08-02-2011, 06:47 AM
steve578
steve578's Avatar
Originally Posted by MCDavis View Post
Looks good, steve!
From my experience, it was 1/4" higher than the stock skid under the bottom. However, the departure angles is reduced since the tank sits further back than stock. Every little bit helps with the longer wheelbase.
I will say that I loved the Safari tank when it was my DD and used it for longer wheeling trips. I just don't have the need for extra capacity anymore.
2013 JKUR
steve578 is offline
post #906 of 927 Old 08-02-2011, 12:12 PM
K-Bomb
I put a nice brushed finish on mine, then gave it a couple coats of clear before installing. It looked fantastic....until the rear started leaking gear fluid from somewhere and ate the clear right off.
K-Bomb is offline
post #907 of 927 Old 08-02-2011, 03:47 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Bummer. The nice thing is it still won't rust and you can clean it up and shoot some more clear on it.
Do you get any pix of it with clear. I've been wanting to do it like that.
Thanks,
Gerald
Like us on Facebook
Savvy is offline
post #908 of 927 Old 08-02-2011, 03:52 PM
robert_hollis
I rattle canned mine black back when I put it on.
You read it. You can't unread it!
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline
post #909 of 927 Old 10-20-2011, 04:41 AM
ImaginaryFriend
ImaginaryFriend's Avatar
So how long is the typical install? Looks like I'll have to do an evening after work install since my GTS is arriving Monday and I have a trip that Saturday.
ImaginaryFriend is offline
post #910 of 927 Old 10-20-2011, 04:52 AM
NotURMailman
It shouldn't be a problem to do it in one evening. Make sure you are very low on gas. It took me about two hours to get mine back in, but it was a relaxed process on a Saturday morning (after I installed the new pump to replace the one I broke while trying to remove a full tank).
Just be easy with the tank until the fuel lines are off of the pump!
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #911 of 927 Old 10-20-2011, 07:23 AM
mike_dippert
mike_dippert's Avatar
I did it by myself with a half tank of gas in a few hours.
mike_dippert is offline
post #912 of 927 Old 10-20-2011, 08:10 AM
biffgnar
biffgnar's Avatar
Helps to have an asistant as it all is a little bulky, but generally agree that its not that big a task.
I'd also suggest running a little bead of grease around the edge of the tank before putting it in the skid. Tolerances are tight and helps to get it fully seated.
Romney in 2020!
biffgnar is offline
post #913 of 927 Old 10-20-2011, 08:33 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Yes, tolerances are tight. No grease needed. Take a file and ease the top inner edge a slight bit if it isn't done already. Sometimes the fab shop forgets and I don't get to inspect all of them.
When that's done, set the tank on top of the skid and ease it down into the skid by jumping up and down on alternate ends.
If you use grease, it will attract grit and may sand something you don't want sanded.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #914 of 927 Old 10-20-2011, 08:41 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Forgot about this thread. May 2012 will be our third anniversary of the introduction of the aluminum gas tank skid and Savvy Off Road. Savvy was lanuched and is introducing new products every month thanks to you guys. To date not a single gas tank skid has failed!
Thanks to all that believe and support us!
Gerald
Like us on Facebook
Savvy is offline
post #915 of 927 Old 10-20-2011, 08:46 AM
SuperWade2
More Money than Brains
SuperWade2's Avatar
Gerald
I hope one of those new products is a rear tire carrier... if so, I'll be on you like a fat kid on free cake to get one ordered!
P.S. I believe...
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
? about gas tank/skid plate Jeepfan Jeff YJ Wrangler Technical Forum 7 01-03-2010 02:15 PM
Aluminum transfer case skid plate Wheelin98TJ TJ Wrangler Technical Forum 12 11-20-2009 09:55 AM
Savvy offroad aluminum gas tank skid plate mustgooverit TJ Wrangler Technical Forum 0 08-26-2009 11:48 PM
Gas tank skid plate Lee3333 YJ Wrangler Technical Forum 7 06-13-2008 06:32 PM
Gas tank skid plate help J13760 YJ Wrangler Technical Forum 1 04-13-2006 11:55 AM
