New gas tank skid plate... can you say aluminum? - Page 59 - JeepForum.com
post #871 of 927 Old 05-16-2011, 08:52 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Originally Posted by Jerry Bransford View Post
Will do Gerald. I never knew you carried those types of parts but if you have a good lower $$$ source for them I'm all over that.
Crown Automotive or Transamerica carry most everything we need.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #872 of 927 Old 05-16-2011, 08:54 AM
jpfelix
i finally put a good dent in mine. the dip in the center doesn't dip on one side.
jpfelix is offline
post #873 of 927 Old 05-16-2011, 09:24 AM
rottenrobert
PICS??? I think we all need to see
There's always time to do it right the second time.
rottenrobert is offline
post #874 of 927 Old 05-16-2011, 09:42 AM
jpfelix
i'll see if i can get some.
jpfelix is offline
post #875 of 927 Old 05-16-2011, 09:47 AM
rondak46
. Went in real easy. Even the fuel lines were going back together by themselves. They self aligned and I just clipped the line connectors. LOVE the skid.
I was also astonished at the fit.
I lifted the skid up on a jack. I just kept going until the rear crossmember bolts were through the skid. I then looked at the axle side bolts and they were all in position. I then looked at the filler hoses; they had found there place too. I couldn't believe it.
rondak46 is offline
post #876 of 927 Old 05-16-2011, 10:06 AM
touched
Nice My gas tank skid should show up by Friday, hope my install goes as easy.
Rokmen TT,Savvy GTS, JKS BL MML,Orr-Fab sport Cage,Rock Hard front bumper,Body Armor side bars,Best rear bumper
Currie HD Steering , Savvy 4" lift, Fox shocks
touched is offline
post #877 of 927 Old 05-16-2011, 05:11 PM
rottenrobert
It will. Just take your time. One tip I can give is to remove both the inlet and return lines at the driver side wheel well. A lot easier to reach then ontop of the tank. Push the connections on further then squeeze the clips and then pull them apart.
Good luck. But I doubt you'll need it.
post #878 of 927 Old 05-16-2011, 08:15 PM
theducksguts
One of the best investments in armor I have made. The thing takes a pounding every trip.
Check out my
theducksguts is offline
post #879 of 927 Old 06-20-2011, 11:46 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
A few people recently asked about the stainless steel straps and hardware. It will only work with our gas tank skid. It was designed so we could push the gas tank as far back as possible.
What a lot of people forget is we included all of the hardware and all of straps. More importantly, is the steel flanges are zinc plated to resist corrosion as well.
The steel flanges are necessary to prevent the rear cross member from folding up. You'll notice the flanges are a lot wider than everyone else and have two rows of holes to accommodate stock and body lifted Jeeps. You can run in either configuration without having to purchase anything else.
Here are a couple of shots of the skid before and after the OEM tank is installed.
Like us on Facebook
Savvy is offline
post #880 of 927 Old 06-28-2011, 08:39 AM
geiman
Any Savvy 4th of July sales? Preparing my list (and my credit card)...
geiman is offline
post #881 of 927 Old 06-28-2011, 08:49 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
JF10 Coupon code is good till July 5th!
Thanks,
Gerald
Like us on Facebook
Savvy is offline
post #882 of 927 Old 06-28-2011, 08:50 AM
geiman
Good to know; Friday is payday!
geiman is offline
post #883 of 927 Old 07-13-2011, 08:11 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Thanks!
Like us on Facebook
Savvy is offline
post #884 of 927 Old 07-26-2011, 05:28 PM
explorerlyon
explorerlyon's Avatar
Completed the install of my Savvy gas tank skid today. Amazing product. Actually, my 17 year old son did most of it himself while I was at work. That says something about the quality of the directions and product ease. A couple of items we did differently than the instructions:
1. Supporting the vehicle with jack stands under the axle pushes the axle up too far making it difficult to unbolt the old skid. The track bar and differential were in the way of wrenching. Supporting the vehicle by the frame so the suspension dropped down made it much easier.
2. The Allen head cap screws that threads into the cross dowels were just a tad short (I was using the longer ones). I inserted two screwdrivers, one on each strap behind the dowels and squoze them together until I could start threading the cap screw into the dowell. 1/4" longer bolt would have been helpful.
Edit: Bolts supplied are long enough. I used the wrong mounting hole in the strap. Should have used top hole on one strap and bottom hole on the other.
Thanks for a great product!!! Off to the Rubicon trail next week to put it to the test!
05 Rubicon Unlimited, Automatic
explorerlyon is offline
post #885 of 927 Old 07-26-2011, 07:21 PM
biffgnar
biffgnar's Avatar
1. Why did you need to jack the vehicle up at all? Been awhile since I did mine but my recollection was that I did it with all four wheels on the ground.
2. I had this same issue. Ended up running to hardware store for slightly longer bolts.
Romney in 2020!
biffgnar is offline
? about gas tank/skid plate Jeepfan Jeff YJ Wrangler Technical Forum 7 01-03-2010 02:15 PM
Aluminum transfer case skid plate Wheelin98TJ TJ Wrangler Technical Forum 12 11-20-2009 09:55 AM
Savvy offroad aluminum gas tank skid plate mustgooverit TJ Wrangler Technical Forum 0 08-26-2009 11:48 PM
Gas tank skid plate Lee3333 YJ Wrangler Technical Forum 7 06-13-2008 06:32 PM
Gas tank skid plate help J13760 YJ Wrangler Technical Forum 1 04-13-2006 11:55 AM
