New gas tank skid plate... can you say aluminum? - Page 56 - JeepForum.com
post #826 of 927 Old 07-03-2010, 10:42 PM
red rubi
So long pal!
red rubi's Avatar
Originally Posted by LuckRider View Post
I just noticed that there are welds on the skid. From doing some research about welding 6061 T6, I found out that welding on it can reduce its strength by up to 80% changing its grade (unless it has been aged or heat treated again).
That's what happens when you let LR stray into the Fab Shop Forums
red rubi is offline
post #827 of 927 Old 07-04-2010, 12:23 AM
jeepwrangler97
If you look in the corners where the drains are, you can see that it's all the way down. Although, you should have put the tank straps on first before you dropped the tank in.
I saw that after I posted it and went outside to look at it again and can see it now
I thought I did the tanks straps in the right order, I bolted them in place, but not torqued down, then dropped the tank into place, is that the right order? Thanks
I'll post pics of the before and after of my clearance gains with my 1"BL and Skid in place, I was having clearance issues with my diff/stock gts and this skid should help tremendously Thanks again for the great customer service and skid
jeepwrangler97 is offline
post #828 of 927 Old 07-04-2010, 01:17 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you did it in that order, then it was correct. I must have missed them in the pics looking at how far the tank was seated. Make sure you get the straps pretty tight.
You're welcome. And don't let the detractors bother you. If you can tear that skid up on the trail, we'll be more than pleased to send you another one if it fails.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #829 of 927 Old 07-04-2010, 01:41 AM
jeepwrangler97
I don't see myself tearing the skid up any time soon, hmmm FL(some IL/MI) wheeling compared to JV, I think I'll be safe.
post #830 of 927 Old 07-04-2010, 01:47 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Ahhhh, come on now, didn't you read? It's not the same as 6061-T6 where it's welded and, and, and, and,
I am Savvy
mrblaine is offline
post #831 of 927 Old 07-04-2010, 01:55 AM
jeepwrangler97
oh, sorry I forgot, you guys didn't put a lot of time into it and you guys don't have any experience and you have no idea what you're talking about
post #832 of 927 Old 07-04-2010, 06:47 AM
RubiconRazorbac
RubiconRazorbac's Avatar
Well then they must all be trashed! I guess I'll just take mine off and use it for a coffee table. Unless it can't hold the weight of a beer stein, some nachos, and a few magazines strewn about
Your shaft isn't long enough to handle that kind of droop...
My build thread:
RubiconRazorbac is offline
post #833 of 927 Old 07-04-2010, 09:11 AM
LuckRider
LuckRider's Avatar
Wow guys, way to take a question and make it sound like a massive argument against the skid. I was just wondering if they retreated it after the welding, or if the loss in strength wasn't something that you needed to worry about.
Thanks to some sarcasm, I have the answer.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #834 of 927 Old 07-04-2010, 09:29 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Just now noticed?
Go look at the second picture in the first post that Jerry started the thread with, no less than a year and 2 months ago.
And I wasn't sarcastic to you, I was beyond sarcastic to the ERS nutswinger who intimated we would try to hide something.
Besides all that, if your question was intended in the way you just clarified it, methinks that's the way you would have asked it.
Like this- Hey, I was digging around on the 'net and learned that when you weld 6061-T6, the heat from welding changes the temper and it's no longer the same strength, I was wondering if you retreated it after the welding, or is the loss in strength something that you needed to worry about?
To which I would have patiently explained why we designed it the way we did.
I am Savvy
mrblaine is offline
post #835 of 927 Old 07-04-2010, 09:41 AM
LuckRider
LuckRider's Avatar
Just now noticed?
Yeah, someone else pointed out my lack of clarification. I never said that the sarcasm was specifically directed at me, but it did tell me what I wanted to know.
As for the pic in the first post, when I first read the thread, I didn't think anything of it.
Support Our Troops!
JFI Member #7:
post #836 of 927 Old 07-04-2010, 09:45 AM
robert_hollis
Hey mrblaine. I'm feeling trollish, so can you patiently explain why my skid came with no instructions and 2 mounting bolts short of a full set?
Just giving you guys a hard time. I picked up the extra bolts at the hardware store, and am planning on installing it sometime before the fireworks tonight.
You read it. You can't unread it!
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline
post #837 of 927 Old 07-04-2010, 10:05 AM
SuperWade2
More Money than Brains
SuperWade2's Avatar
Directions are on the Savvy website... Let me know if you'd like a copy...
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #838 of 927 Old 07-04-2010, 10:08 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The lack of hardware is inexcuseable and unfortunately without counting out every package ourselves, it's going to happen from time to time, although how something as simple as putting bolts in a bag can get screwed up, is beyond me.
Wade and Gerald have the directions in PDF form on our website somewhere and you are supposed to be able to download them and print them out. I'm guessing though, that if there is not a note in the box with the product that explains that, the end result of not having instructions will be the same.
What fasteners were missing? If it was the carriage bolts, please check the grade. We use grade 5 to get the clamping force needed and I have yet to see anything but unrated carriage bolts at any hardware store I've been to.
If they are not grade 5 minimum, do not use them.
I am Savvy
mrblaine is offline
post #839 of 927 Old 07-04-2010, 10:08 AM
robert_hollis
Ok, SuperWade. It's all good, though. I've always enjoyed puzzles, so anytime I get to put something together (automotive or otherwise) I look at it as a new puzzle to play with.
post #840 of 927 Old 07-04-2010, 10:11 AM
robert_hollis
mrblaine, I went by Fastenal, and got some grade 5 carriage bolts. They know me there, cause I'm always coming in looking for 10.9 metric bolts, and such.
? about gas tank/skid plate Jeepfan Jeff YJ Wrangler Technical Forum 7 01-03-2010 03:15 PM
Aluminum transfer case skid plate Wheelin98TJ TJ Wrangler Technical Forum 12 11-20-2009 10:55 AM
Savvy offroad aluminum gas tank skid plate mustgooverit TJ Wrangler Technical Forum 0 08-27-2009 12:48 AM
Gas tank skid plate Lee3333 YJ Wrangler Technical Forum 7 06-13-2008 07:32 PM
Gas tank skid plate help J13760 YJ Wrangler Technical Forum 1 04-13-2006 12:55 PM
