New gas tank skid plate... can you say aluminum? - Page 50 - JeepForum.com
post #736 of 927 Old 01-03-2010, 10:11 AM
andito77
I'm adding this in case it might help anyone else.
To de-pressurize the fuel system, I pulled out the fuel pump relay in the fuse panel under the hood, and turned the key like I was going to start the Jeep. It fired for a second, and then died. I had a couple of drops come out when disconnecting. After installing, I replaced the fuel pump relay and keyed the ignition on and off a few times to pressurizize (Bushism) the fuel system, and it fired right up and ran great.
Like I said, I added this, because I don't have a Factory Service Manual, and it was the only thing I could think of, and it might make someone else's life easier.
andito77 is offline
post #737 of 927 Old 01-03-2010, 10:34 AM
creepycrawly
creepycrawly's Avatar
I am just wondering if anyone has tried one of these with the RE Tri-link rear setup? I am in the market for one because my 01 has the worst stock skid ever...it is completely open on the sides unlike my 02 which is closed in and I am concerned about clearance issues.
You can't be first, but you can be next!
creepycrawly is offline
post #738 of 927 Old 01-03-2010, 10:35 AM
biffgnar
biffgnar's Avatar
Thats how the Rokmen guys do it on their video on youtube
Romney in 2020!
biffgnar is online now
post #739 of 927 Old 01-03-2010, 11:31 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
I don't know about the RE Trilink but we have many peopleusing our skids with triangulated 4 link suspension. In fact, they like our skid better because they are able to shift the axle back more than the others.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #740 of 927 Old 01-03-2010, 11:55 AM
rmb2485
rmb2485's Avatar
Any updates on the belly skid yet????
rmb2485 is offline
post #741 of 927 Old 01-03-2010, 04:04 PM
89yjon
X2!!!
89yjon is offline
post #742 of 927 Old 01-03-2010, 05:31 PM
LuckRider
LuckRider's Avatar
I think that is x 90% of the TJ forum
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #743 of 927 Old 01-03-2010, 07:55 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
Yes... I'm running the RE Truss, but I have it mounted on top for my Diff instead of at the face Pic Here... I can't find the other Savvy install pics right now, but I had one of the before and after clearance between my Kilby GTS and the Savvy GTS... the Savvy had better clearance by a noticeable amount
I can take some other pics if you had specific things you wanted to see, but I wouldn't worry one bit!
Sw2
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #744 of 927 Old 01-03-2010, 08:09 PM
Humboldt
Humboldt's Avatar
Some savvy clearance sexiness
This is with 16" lowers on a D44 tilted back far enough to adjust the pinion with a 4" lift and Tera Belly Skid (Equal to 6.5"+ of total drive line lift.)
Just enough room for the diff to stuff all the way up there
Humboldt is offline
post #745 of 927 Old 01-26-2010, 12:38 PM
mudb8
want it rite or rite now?
mudb8's Avatar
well, the
tank skid made the JP magazine march 2010 pages!
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #746 of 927 Old 01-26-2010, 12:53 PM
SimonsTJ
I installed the Savvy GTS over the summer and it has been fantastic. I don't do any hard core wheeling like Blaine and Gerald do, but so far I have only been able to put small scratches and one little dent in mine. Now I need a BL (among other things) so I can tuck the skid up a bit more.
Indy is my new BFF!
SimonsTJ is offline
post #747 of 927 Old 01-26-2010, 03:47 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Looks like you're definately having some fun!
Like us on Facebook
Savvy is offline
post #748 of 927 Old 01-26-2010, 03:55 PM
SimonsTJ
Haha, I have as much fun as I can with my little Jeep
Indy is my new BFF!
SimonsTJ is offline
post #749 of 927 Old 01-26-2010, 04:00 PM
LuckRider
LuckRider's Avatar
x2 .
Support Our Troops!
JFI Member #7:
post #750 of 927 Old 01-26-2010, 04:10 PM
Lil Chris
With a 97-02 you should be able to raise it up without the body lift. The extra junk on top of the 03-06 TJs prevent this from happening. On my old 97 I had an EMP skid that raised the tank up an extra inch with no issues whatsoever.
Lil Chris is offline
? about gas tank/skid plate Jeepfan Jeff YJ Wrangler Technical Forum 7 01-03-2010 02:15 PM
Aluminum transfer case skid plate Wheelin98TJ TJ Wrangler Technical Forum 12 11-20-2009 09:55 AM
Savvy offroad aluminum gas tank skid plate mustgooverit TJ Wrangler Technical Forum 0 08-26-2009 11:48 PM
Gas tank skid plate Lee3333 YJ Wrangler Technical Forum 7 06-13-2008 06:32 PM
Gas tank skid plate help J13760 YJ Wrangler Technical Forum 1 04-13-2006 11:55 AM
